Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Diff additive question...
  #16 (permalink)
Old 11-09-06, 11:53 PM
Got5onit's Avatar
Cadillac(s): LS6 V
View Got5onit's Photo Album
Casino Cash: $1565
Re: Diff additive question...
Had a new '06 diff installed in my '04 V last week. I immediately came home and changed it to Royal Purple 75w90 synthetic. When the break in period passes, I'll be switching to Red Line.
Royal Purple synthetic gear oil can be bought at O'Reilly auto parts.
  #17 (permalink)
Old 05-26-07, 11:30 AM
austin's Avatar
Cadillac(s): ~2004 CTS-V, 2006 STS-V, 2007 Escalade~
View austin's Photo Album
Casino Cash: $6477
I had a 06 diff installed a few weeks ago... The service sheet list theree part numbers, one for the diff., one for the fluid, and one for the vent kit. I asked about the posi-additive, and they said it is not needed as the fluid is synthetic. Will not having the additive eventualy burn out the posi clutches?
  #18 (permalink)
Old 05-26-07, 02:17 PM
rand49er's Avatar
Mods on hold till diff gets fixed.
Cadillac(s): 2005 CTS-V
View rand49er's Photo Album
Casino Cash: $47894
Had mine done last July, and it lists four part nos:
1) 12793756 carrier 5.505
2) 89021677 gear lubr 8.800
3) 1052358 addt 8.800
4) 25730853 vent 5.387
'05 CTS-V, Stealth Gray, Sunroof, 3M Clear Bra, B&M Shifter w/UUC Bushings, Specter Werkes Bushings, V Headrests, Wheel To Wheel Powertrain Tune, Corsa, Kooks w/Hi-Flo Cats, Ultimate Grid Pedals, Hotchkis Anti-Sways, STS-V Fogs, Ground Control 650R/600F, WW Clear Sidemarkers, Full-Size Spare, Magnuson SC Polished, CTS Console, FG2, Aggressive Street Alignment, MOMO Shift Knob, DSS/Hendrix Engrg Axles, UUC Flywheel. Soon: UUC MMs. 472 RWHP/411 RWTQ (Mustang dyno).
  #19 (permalink)
Old 05-26-07, 04:01 PM
Flyboy's Avatar
Piaggio Pilot
View Flyboy's Photo Album
Casino Cash: $5730
It NEEDS the additive! !! !
I repeat.......It NEEDS the additive! ! ! !
  #20 (permalink)
Old 05-26-07, 04:38 PM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $16917
Tell them to refer to SI Document ID# 1387214 which can be accessed by going to the owner's manual section in SI and searching for Lubricants.
Under rear differential they will find this EXACT TEXT:
SAE 75W-90 Synthetic Axle Lubricant (GM Part No. U.S. 12378261, in Canada 10953455) meeting GM Specification 9986115. With a complete drain and refill add 4 ounces (118 ml) of Limited-Slip Axle Lubricant Additive (GM Part No. U.S. 1052358, in Canada 992694) where required. See Rear Axle
Also refer them to Document number 803844 which is a procedure for changing the differential fluid. It states the following in RED TEXT:
Important: If equipped with a limited slip differential, limited slip differential lubricant additive, GM P/N 1052358 (Canadian P/N 992394) or equivalent must be added first. Refer to Lubrication Specifications . Approximately 0.23 L (7.8 oz) of residual fluid will remain in the differential.
(presumably because it is important)
If a parts person punches in the 12378261 part number it will change numbers to the number listed above that ends with 1677.
It does need the additive, if they don't put it in you'll have chatter problems on turns. (using the "chatters on turns" diagnostic chart takes you to the document I mentioned above.
It won't do any short term damage.
Tell them a World Class GM Tech friend of yours told you that you need the additive.
Tags: , ,
additive, diff, question
Censor is OFF
