| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Spare Tire Kit for the V?
01-31-07, 06:18 PM
| | Cadillac Owners Member Cadillac(s): 02 sls & 06 Gray Thing | | Join Date: Jan 2007 Location: Maywood IL Age: 96 | | | Re: Spare Tire Kit for the V? I tried to talk Sewell before I bought this one.
My local dealer said they saw 1 CTS-V before. I need to find a dealer
in the Chicago area before I really need to.
Reason: bad speling
01-31-07, 06:36 PM
|  | Moon Parasite Cadillac(s): 2006 STS-V BlackonBlack / 2005 CTS-V Redline (traded in) | | Join Date: Dec 2005 Location: D/FW Tejas | | | Re: Spare Tire Kit for the V? Quote:
Originally Posted by urbanski everybody associated with Sewell knows nothing at all....about anything |
That's not the whole truth. Some do. But MOST dealerships (Lindsay excluded) do not hardly know this car.
It looks like Tire Rack is finally out of the Millie wheel for the V. Too bad because that was a pretty good deal to make a spare with.
__________________ |
02-01-07, 02:36 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2004 CTS-V | | Join Date: Mar 2005 Location: Gillette, WY Age: 28 | | | Re: Spare Tire Kit for the V? Quote:
Originally Posted by JJKJ Not to get too far off track, but while at the local Autozone I noticed that they have a kit similar to the Z06 kit--it has the mini air compressor, a can of fix a flat, and a couple other items all packaged into a small cube. Price was $19.99. I didn't get one, but once my run-flats are gone, I'll probably pick one up for the price and convenience.
John | Sorry about the psuedo-threadjack but the topic is along the same lines so I will ask anyway. I would rather just do this kit for piece of mind but I heard that the fix-a-flat could screw up the TPSs, does anybody have experience with this? I though somebody once said that you could just wash of a TPS coated with the fix-a-flat stuff and it would work just fine. Anybody know?
__________________ 2004 CTS-V Mods: Lingenfelter CAI, OEM style spoiler, CCW SP600 wheels (19"x9" and 19"x10"), Toyo Proxes R888 (F: 235/35YR19 - R: 295/30YR19), Magnaflow Cat-back, UUC Shifter w/ Lindsay bushings, FG2 shocks, GC Coilover Kit (600f/650r), Hotchkis Swaybars, Custom FRCs, Kooks 1 3/4" Cermakromed LT Headers & HiFlo cats, ARP Header Studs, Granatelli 1200* Wires, NGK TR55ix Plugs, OC Autosports D&S Rotors, Hawk Pads, SS Brake Lines, 561 Wheelhop Kit, D.R.E. Dyno Tune = 351 hp/ 365 ft-lbs (corrected) |
03-09-09, 02:15 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2005 Platinum on Silver Cadillac CTS-V | | Join Date: Mar 2009 Location: Houston, TX Age: 27 | | Re: Spare Tire Kit for the V? Just bought a certified '05 V...I'm in Houston and would love some help locating a V rim and used tire to use as a spare!
Found the remainder of the kit on FAQ. |
03-09-09, 05:33 PM
| | Cadillac Owners Connoisseur | | Join Date: Feb 2004 Location: Conroe, Texas Age: 41 | | | Re: Spare Tire Kit for the V? AG'S-V,
You have a PM.
I have a "V" wheel mounted with an almost new runflat, tub, jack and handle for sale. I"m in Conroe so you could pick it up.
Shane |
03-09-09, 07:01 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Spare Tire Kit for the V? I am looking for 3 stock CTS-V wheels in poor cosmetic (CHEAP) but perfect functional condition. I just need a set of track rims and I already have one road rashed rim.
__________________ R.I.P. Cadillacforums..... |
05-02-09, 12:45 AM
| | Cadillac Owners Member Cadillac(s): '05 CTS-V Platinum | | Join Date: Mar 2008 Location: Houston, TX Age: 35 | | | Re: Spare Tire Kit for the V? Quote:
Originally Posted by svassh ...I mentioned this to the dealer and they have offered to get me a spare kit...
Kit on order and should be in this week. Just wondering if anyone has heard of this or has it yet.
If not I'll let ya'll know how it turns out and what the part number is if interested. | What ever happened with this, did you get a spare wheel/tire with the kit, or was it just the jack etc.?
I'm looking for the hookup myself.
Anybody else explored the wheel hub adaptors for use with a cheap steel wheel?
The SRX has the same lug spacing as the CTS-V and there is a 17 x 4 (donut) spare offered with the SRX. I'm going to try and find one at a junkyard. That along with a 10mm spacer should work, I think, I don't know about the diameter, though, might take some work.
A donut spare would be pretty sweet, weight savings wise. |
05-02-09, 02:26 PM
| | Cadillac Owners Member Cadillac(s): CTS-V | | | | | Re: Spare Tire Kit for the V? Quote:
Originally Posted by dmilamj What ever happened with this, did you get a spare wheel/tire with the kit, or was it just the jack etc.?
A donut spare would be pretty sweet, weight savings wise. | I was thinking about doing the same thing. Saw that the SRX spare was $70 shipped from gmpartsdirect. Not sure if that is just for the wheel but I would assume it includes the tire too. Then getting the other parts from the FAQ.
Does anyone know if there is a reason the factory jack or container listed in the FAQ would not fit in the SRX spare? |
05-03-09, 12:58 AM
| | Cadillac Owners Member Cadillac(s): '05 CTS-V Platinum | | Join Date: Mar 2008 Location: Houston, TX Age: 35 | | | Re: Spare Tire Kit for the V? Oh, the GM OEM jack and container will fit without any problem, I'm sure. It might rattle around a little in all the space that will be left over.
The SRX donut is only a 4" wide wheel, compared to the stock CTS-V 8", so there will be space in the spare tire wheel well for the wheel, the jack, and probably a few pizzas, too.
I have no idea how to tell what will be required to make the donut fit on the car though, I think the trick will be brake clearance.
The SRX has a 51mm offset, compared to the V's 42mm. Not sure how that will affect things since the donut is so much thinner than a standard wheel.
There maybe a spacer involved, which would be a hassle, but might be worth it.
Maybe I can find a local SRX owner, borrow their spare, and see how it fits. Anybody have an SRX hookup or know anyone over in the SRX area? I'll drop a post over there and see if any lives/works around me. |
05-03-09, 02:28 AM
Originally Posted by dmilamj Oh, the GM OEM jack and container will fit without any problem, I'm sure. It might rattle around a little in all the space that will be left over.
Maybe I can find a local SRX owner, borrow their spare, and see how it fits. Anybody have an SRX hookup or know anyone over in the SRX area? I'll drop a post over there and see if any lives/works around me. | Coulter Cadillac at the Tempe Autoplex uses Enterprise Rental for their loaner cars. Last time I was there thats what they gave me. I will go over Monday on my lunch break and see if they will let me test it out... I will bring my camera  |
05-03-09, 10:14 PM
| | Cadillac Owners Member Cadillac(s): '05 CTS-V Platinum | | Join Date: Mar 2008 Location: Houston, TX Age: 35 | | | Re: Spare Tire Kit for the V? Nice.
Not sure if we'll be able to tell about the fit without actually trying to get the spare on the car though...but definitely worth a good look. |
05-03-09, 11:53 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Spare Tire Kit for the V? Quote:
Originally Posted by dmilamj I think the trick will be brake clearance. | I really don't see any way that this would would clear the V's front brakes  |
05-04-09, 01:25 AM
Originally Posted by LT4POWR I really don't see any way that this would would clear the V's front brakes  | Thats what I am planning on testing out. Either way... you really only need to clear the rear brakes... It would just be a pain moving the rear tire to the front then putting the spare on back. |
05-04-09, 12:37 PM
| | Cadillac Owners Member Cadillac(s): '05 CTS-V Platinum | | Join Date: Mar 2008 Location: Houston, TX Age: 35 | | | Re: Spare Tire Kit for the V? Spacer?
I don't know. An online wheel offset calculator that I found says that a 5mm spacer would work, but I have no experience in this matter (and that's assuming that the donut will have the same offset as the stock SRX wheel, which is probably not right at all, now that I think about it.)
I just bought my V and haven't even taken a wheel off yet!
I'm just looking for a light-weight spare-tire solution so I don't have to lug 40#s of tire in my trunk all-day everyday.
I'm waiting (not so) patiently for Eric's findings. Quote:
05-06-09, 11:58 AM
Originally Posted by Eric Pittman Thats what I am planning on testing out. Either way... you really only need to clear the rear brakes... It would just be a pain moving the rear tire to the front then putting the spare on back. | Any luck trying this out? Quite curious about what type of spacer might be required.... | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
