Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Swaybar endlink clunk question
Old 07-11-06, 01:55 AM
VELOSE's Avatar
Cadillac(s): CTS-V
View VELOSE's Photo Album
Casino Cash: $300
Question Swaybar endlink clunk question
I just replaced my stock swaybar endlinks for these, http://www.vbandp.com/detail.aspx?ID=755.
I sized them up to be like stock. However, I'm getting a clunk from what seems to be all four corners. What do I need to do? Should I adjust them to be shorter?
The car is on stock springs, FG2 dampers, and Hotchkis sways. Any help is appreciated.
  #2 (permalink)
Old 07-11-06, 07:24 AM
rand49er's Avatar
Mods on hold till diff gets fixed.
Cadillac(s): 2005 CTS-V
View rand49er's Photo Album
Casino Cash: $47894
Re: Swaybar endlink clunk question
Are the bolts tight?
I had a similar problem on my right front when I installed my Hotchkis ... sounded like the car was 10 years old! I used a metric Allen wrench and "Voila," it's now smooth and quiet.
  #3 (permalink)
Old 07-11-06, 11:31 AM
Rey Rey is offline
View Rey's Photo Album
Casino Cash: $5935
Obviously, correct torquing the end links is critical.
My favorite shop installed my Eibach front bars backward, stressing the end links so that they broke. While waiting for delivery of new end links, I made up some temporaty end links using bar stock and grade 8 bolts. They worked well. By the way the price for the aftermarket end links is less than OEM at GM Parts Direct.
  #4 (permalink)
Old 07-11-06, 12:57 PM
VELOSE's Avatar
Cadillac(s): CTS-V
Casino Cash: $300
I'm sure the bolts and nuts are tight. I did notice one had slightly bent. I'll go and check everything again today. If it's tight, I'm going to adjust them down a bit. Go for a drive and see if it clunks more or less. If I can't make them quiet, I'm going back to stock endlinks.
  #5 (permalink)
Old 07-11-06, 01:26 PM
Cadillac(s): 04 CTS-V
View kgoch's Photo Album
Casino Cash: $3245
The heim joints shown on those end links are steel. They will not last and will become loose, making a clunking noise. Use teflon lined heim joints and the noise will go away.
  #6 (permalink)
Old 07-11-06, 02:05 PM
VELOSE's Avatar
Cadillac(s): CTS-V
Casino Cash: $300
Take me as a noob on this. "Heim joints" are the metal round pieces where the bolt goes thru?
Better yet, any chance you can link me to a set of teflon lined heim adjustable joints?
  #7 (permalink)
Old 07-11-06, 04:54 PM
Casino Cash: $3245
Go to pegasusautoracing.com and click on suspension, then click on Aurora rod end bearings. If you check these have teflon lining.
  #8 (permalink)
Old 07-11-06, 10:30 PM
calicadi's Avatar
Cadillac Owners Enthusiast
Cadillac(s): CTS-V
View calicadi's Photo Album
Casino Cash: $350
See Hotchkis p/n 1797 (the pic is old they don't really look like this). They are fully adjustable, non-heim, high-articulation units with lube fittings. The only problem... sized for 'vette sways. If we go with these we'll have to drill our sways. Drew owes me an answer on whether they have any comparable to these that do not require drilling. He must've forgotten about me. Call him and bug him. I will, too 'cause it looks like the GC c-overs are imminent.
  #9 (permalink)
Old 07-12-06, 01:29 AM
VELOSE's Avatar
Cadillac(s): CTS-V
Casino Cash: $300
I drilled my sways to fit these adjustable endlinks. I needed a 1/2" opening to fit the new bolts. I've realized with the help of my neighbor, these vpband endlinks are a P.O.S.! The pieces that swivel on these heim joints were really loose. Basically they were worn out. They aren't up to the task. The correct endlinks to use would be the ones recommended by kgoch. They are teflon coated. I ended up putting the stocks back on because I put my stock springs back in. I hope the larger openings don't cause the stock endlinks to clunk too. I didn't have time to test drive the car. I'll do so tomorrow.
  #10 (permalink)
Old 07-12-06, 09:59 AM
wildwhl's Avatar
Cadillac Owners Master
View wildwhl's Photo Album
Casino Cash: $415
Gotta say, the Z06 endlinks work perfectly on the front (for lowered vehicles).
WW
  #11 (permalink)
Old 07-12-06, 02:08 PM
VELOSE's Avatar
Cadillac(s): CTS-V
Casino Cash: $300
I slapped the stock endlinks on yesterday. I didn't have a chance to drive the car. I will when I get home. I hope it doesn't clunk.
  #12 (permalink)
Old 05-25-09, 01:43 PM
Cadillac(s): Raven Black 2004 CTS-V. Broken Diff!
View mpunklil's Photo Album
Casino Cash: $2505
Im sorry to dig up an old thread, like a 3 year old thread lol. What did you you guys end up doing? I hope you still check this site :P
  #13 (permalink)
Old 05-25-09, 02:04 PM
Cadillac(s): 05 Raven V
View CTS-Voodoo's Photo Album
Casino Cash: $6745
Holy crap! They charge 119 for those things? I could make them out of FK sphericals for that!!!
  #14 (permalink)
Old 05-25-09, 02:28 PM
Casino Cash: $2505
still cheaper than the 160 im blowing on p.o.s. powergrids that ive snapped twice
  #15 (permalink)
Old 05-25-09, 07:18 PM
Cadillac(s): Cadillac
View psycho43142's Photo Album
Casino Cash: $3645
Why not use the stock ones then, I AX mine on R compounds and have never had a problem.
Tags: , , ,
clunk, endlink, question, swaybar
Censor is OFF
