Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: a/c doesnt work while idle!!!
    1fstkde's Avatar
    1fstkde is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 stsv. 2005 ctsv(r.i.p)
    Jul 2005
    los angeles
    581
    does anyone else have this problem??? my a/c blows only cold when im driving or high rpms, when im stopped or in traffic it blows warm!!! please help!!
  2. #2
    ctsvett's Avatar
    ctsvett is offline FAQ is your Friend
    Automobile(s): CTS-V
    Feb 2003
    California
    3,987
    Re: a/c doesnt work while idle!!!
    few questions:
    1. maggie?
    2. Tune or ECM program?
    3. Fan works normal right? It doesn't stop blowing, just blows hot air?
    4. does the car Idle low or shaky?
    Just initially, sounds like could be the clutch disengaging on the A/C Compressor which can be caused by the following:
    1. Refrigerant sensor
    2. AC clutch relay
    3. Wiring issues (any bare wires visible) any recent mods that could have changed something?
    4. AC control module
    Reed
  3. #3
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Sounds like a possible cooling fan problem or a low refrigerant charge.
  4. #4
    NORRISK66 is offline Cadillac Owners Member
    Automobile(s): 2000 DTS
    Nov 2005
    Golden, CO
    19
    how hot/how much humidity outside when this is happening?
    might be normal (i know you really wanted to hear that!)
  5. #5
    Innocent Bystander is offline Cadillac Owners Member
    Automobile(s): None
    Nov 2003
    50
    Also, make sure the airflow through the radiator is not constricted. If it's blocked from those crappy little cotton-like things that fly through the air, it'll prevent the A/C system from exchanging the the hot refrigerant for cooler stuff. I just had to hose off my home A/C unit because it was full of those things!
  6. #6
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    There was an old thread about A/C problem(s) and from what I remember it wasn't pretty what had to be removed (just about everything) to service the system.
    I think it was Lindsey that posted some pics.
  7. #7
    1fstkde's Avatar
    Jul 2005
    los angeles
    581
    Quote Originally Posted by ctsvett
    few questions:
    1. maggie?
    2. AC clutch relay
    Reed
    only mods i have is lpe intake, and full corsa....fan works great, wish it would blow harder though, but never ice cold, just cold..stops blowing cold when the car comes to a stop or slow roll, when the rpm drops to idle or just above..then just blows warm...almost like i drive a 4 cylinder rather than a v8..did notice a little shaky idle yesterda only when the ac was on and at a stop..
  8. #8
    1fstkde's Avatar
    Jul 2005
    los angeles
    581
    Quote Originally Posted by NORRISK66
    about 98, no humidity though...typical cali weather..
  9. #9
    Nov 2005
    Golden, CO
    19
    in that temperature-gm says that the max a/c temp at the duct should be 57 degrees F. if it is more than that i would suspect something is wrong.
  10. #10
    Nov 2004
    8,788
    If I remember correctly I think it was called the "expansion valve".
    Is a real mess to get at and service.
  11. #11
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    If you are talking about the "thermal expansion valve" or TXV, yes it CAN go bad, it CAN leak and it IS a pain in the rump to get out.
    It takes about 6 hours and requires removal of the dash.
    I have done 2, seen one other one done and heard of a couple more.
    You can look above your gas pedal and on the side of the HVAC case. See if there is a green oily substance in that area. It could indicate a leaking TXV seal.
  12. #12
    Mary Ann is offline Cadillac Owners Member
    Automobile(s): 04ext,10cts-v,09srt8
    Jul 2012
    nj
    6
    i know it is 6 years later but did you ever find out what was wrong with your truck? i have the exact same problem. thanks Mary Ann
  13. #13
    perfect's Avatar
    perfect is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac CTS-V Platinum
    May 2008
    Kansas City
    33
    1,182
    Mary Ann - you appear to have a 2010 CTS-V. There is a separate forum for 2nd generation V's (this is the 1st gen V forum):
    http://www.cadillacforums.com/forums...al-discussion/
  14. #14
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    Quote Originally Posted by perfect View Post
    Quote Originally Posted by Mary Ann View Post
    ... did you ever find out what was wrong with your truck? ...
    I think she thought he had an LS2.
  15. #15
    May 2006
    81
    I am also curious if you determined what the actual problem was and what it took to fix? I am having the exact same problem now.
  • You may not post replies
