Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Car is Back (New Oil Pump)
Old 02-22-06, 08:43 PM
View ssmith100's Photo Album
Casino Cash: $8726
Just picked up my car. They replaced the oil pump and some misc items. Seeing a whole lot more oil pressure with the new pump versus old. At higher rpm's the car is reading 65 to 70 psi versus around 52 with the old. Idle is around 40 and normal cruising around 50. These numbers seem about right to you guys??? Repair manual only list low pressure reading and not high.
Shane
  #2 (permalink)
Old 02-22-06, 08:53 PM
Geno's Avatar
Cadillac Owners Enthusiast
Cadillac(s): Orginal owner; 2004 CTS-V
View Geno's Photo Album
Casino Cash: $275
Re: Car is Back (New Oil Pump)
65 to 70 seems too high. I don't recall any car I've ever owned that had pressure that high....but better a lot of pressure than no pressure I guess. Most oil gages only go up to 80 psig.
  #3 (permalink)
Old 02-22-06, 09:02 PM
DILLIGAF's Avatar
Cadillac(s): 04 ctsV platinum,maggied,rt cats,headers,corsa,stealth tune
View DILLIGAF's Photo Album
Casino Cash: $14328
I wonder if they can recalibrate those readings.Sounds pretty high.Better get Reed or Stealth involved here.You will know if those readings are correct because oils gonna leak from some where.IMO
  #4 (permalink)
Old 02-23-06, 12:58 PM
View Barak's Photo Album
Casino Cash: $350
If you figure 10psi for every 1000rpm then 65-70psi is perfect.
  #5 (permalink)
Old 02-23-06, 01:22 PM
thefly's Avatar
Cadillac(s): 2006 CTS-V
View thefly's Photo Album
Casino Cash: $1260
at WOT in my ZO6 i saw 80+ psi. sounds normal. with no load usually around 25-40. only reason i thought to add this they both are LS6s...
  #6 (permalink)
Old 02-23-06, 02:21 PM
Cadillac(s): 05 CTS-V
View TampaV's Photo Album
Casino Cash: $2290
I have dyno tested many Z06 Vettes with the same LS6 engine. 65 to 70 is perfect at redline.
  #7 (permalink)
Old 02-23-06, 02:23 PM
my name is Tiffany
View urbanski's Photo Album
Casino Cash: $1133630
sure wish i could check mine for ya
but she's STILL in the freaking body shop, STILL swirled all to hell...waiting to be fixed....2 weeks now.
At least I ahve a 06 SRX loaner, and my new rear diff is in the mail
  #8 (permalink)
Old 02-23-06, 02:38 PM
NH Vrod's Avatar
View NH Vrod's Photo Album
Casino Cash: $250
I read somewhere that anything over 35 PSI of oil pressure at any RPM is a waist of HP ??
Go figure...
  #9 (permalink)
Old 02-23-06, 03:44 PM
Casino Cash: $8726
Thanks guys. The tech called Cady this morning and they said it is in normal range. I just didn't want to walk out one morning and find a pool of oil underneathe the car.
Shane
  #10 (permalink)
Old 02-23-06, 07:42 PM
benjet's Avatar
View benjet's Photo Album
Casino Cash: $250
Go figure...
I would guess that's vehicle or engine dependent, many cars (ok ones from a certain non german european country) usually hover between 70-85psi @ idle and ~110psi for redline.
  #11 (permalink)
Old 03-01-06, 12:47 PM
Cadillac(s): Escalade
View gparmlee's Photo Album
Casino Cash: $275
I had the same problem, they replaced the oil pump and i too have seen numbers in the 70psi range, my solution was to get rid of the car which I am working on as we speak.
  #12 (permalink)
Old 03-02-06, 12:04 AM
Dennisscars's Avatar
Cadillac(s): '05 CTS-VM 51 track days in Maggied V & 50+ in Atom
View Dennisscars's Photo Album
Casino Cash: $4294
that's the best rule of thumb..been usin' that one for years..
  #13 (permalink)
Old 10-13-09, 01:11 PM
Cadillac(s): 2005 Cadillac CTS-V
View CTSVetteMark's Photo Album
Casino Cash: $325
Hey; I brought my '05 CTS-V in to fix a leaking rear differential seal, and when I picked it up, NO oil pressure! After 2 weeks the dealer said the repalced the oil pump and all was fixed. However, when I start the car, NO oil pressure, then it builds back to about 30psi; it used to run 40-45 psi when cold. How much $$$ does it cost to replace the oil pump, as I'm thinking the dealer did NOT do it (and the car is out of warranty!).
Thanks!
Tags: ,
back, car, oil, pump
Censor is OFF
