| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Report all diff problems
02-05-06, 03:15 PM
|  | Super Moderator Cadillac(s): 4.9 STS and stuff. | | Join Date: Sep 2003 Location: St Louis MO Age: 28 | | | Report all diff problems |
02-05-06, 03:29 PM
|  | Cadillac Owners Connoisseur | | Join Date: Apr 2005 Location: Aiken, SC Age: 34 | | | Re: Report diff failures! Can someone explain what this site is, what they do with the info, and how this will help. I'm going to post a compliant but I would like to know exactly what the site does. Thanks!  |
02-05-06, 03:51 PM
| | Cadillac Owners Fanatic | | | | | Re: Report diff failures! National Highway Traffic Safety Administration |
02-05-06, 03:56 PM
|  | Cadillac Owners Member Cadillac(s): 05 maggied CTS-V, 03 maggied Z06 | | | | | Re: Report diff failures! Reported mine
__________________ I am so expensive I can't even afford to hire me.... |
02-05-06, 03:57 PM
|  | Cadillac Owners Member Cadillac(s): 05 maggied CTS-V, 03 maggied Z06 | | | | | Re: Report diff failures! Quote: |
Originally Posted by Joey'sVee Can someone explain what this site is, what they do with the info, and how this will help. I'm going to post a compliant but I would like to know exactly what the site does. Thanks!  | Go to the site and read the instructions.
It creates a Federal database.
It sometimes triggers recalls.
It can give the auto companies major heartburn. |
02-05-06, 04:00 PM
| | Cadillac Owners Fanatic | | | | | Re: Report diff failures! Reported mine |
02-05-06, 04:22 PM
|  | Cadillac Owners Master | | Join Date: Mar 2004 Location: Reno, NV | | | Re: Report diff failures! Done, finally.
Curious - some will report under 04, 05 or 06...will they compile them together for the platform, or should we all just say report them as 05's? |
02-05-06, 04:26 PM
|  | Cadillac Owners Member Cadillac(s): 05 maggied CTS-V, 03 maggied Z06 | | | | | Re: Report diff failures! I was gonna call on monday and bring that to their (NHTSA) attention as I assume GM is gonna try to fold in these failures with the regular CTS and skew the results in their favor. |
02-05-06, 04:32 PM
|  | Cadillac Owners Master | | Join Date: Mar 2004 Location: Reno, NV | | | Re: Report diff failures! True, they might. There have been substantial CTS/SRX failures too (whining only that I know of) but I'm doubtful those complaints are there. |
02-05-06, 05:06 PM
| | Cadillac Owners Connoisseur Cadillac(s): Lemon Law'd '05 V | | Join Date: Feb 2005 Location: Long Island, NY | | | Re: Report diff failures! Complaint submitted... |
02-05-06, 11:42 PM
|  | Differential Slayer | | Join Date: Feb 2004 Location: Chesapeake, VA Age: 43 | | | Re: Report diff failures! Tonight I reported the information below to the NHTSA. If this helps even one V owner I've done my best.
2005 Cadillac CTS-V
VIN 1G6DN56S25013XXXX
Purchased 12/16/2004
Reported to NHTSA – Complaint # 10149XXX
4/11/05 – 8,367 Miles – 1 day out of service
Rear End Failure
4/28/05 – 9,664 Miles – 5 days out of service
Rear Bushing Failure
Rear End Failure
5/5/05 – 9,720 Miles – 1 day out of service
Rear End Failure
Wheel delivered from factory will not balance – no sign of damage
7/25/05 – 15,732 Miles – 4 days out of service
PCM recall #05544– dealer unable to reprogram
Rear end hops wildly in rainy or slick roads when accelerating
Hard shifting into 1st gear
Rear end whine
Drive line clunk
Parking Brake goes to floor and won’t stop car
Rear End Failure
Dealer replaced rear differential and did not add friction modifier, claimed CTS-V’s do not need – later determined this was incorrect
8/29/05 – 17,372 Miles – 22 days out of service
Rear end grinding – Friction modifier added
Transmission rebuilt
Replaced Pressure Plate
Replaced Clutch – TSB 05-07-31-001
Rear End bushings installed to reduce wheel hop TSB – 05-04-114-001A
Navigation system replaced after all buttons were peeling
PCM Recall performed
10/6/05 – 18,990 Miles – 0 day out of service
Navigation System not programmed properly by dealership – returned for repair
11/5/05 – 22,151 Miles – 0 day out of service
Replace all center caps – peeling
1/2/06 – 27,171 Miles – 10 days out of service
Rear End Failure
Radiator Failure – TSB 05-06-02-005A
Sun Visor replaced due to peeling
1/19/06 – 27,538 miles – 6 hours out of service
PCM removed and replaced at ASM's request
1/26/06 – 28,000 miles – 2 hours out of service
Navigation System removed and replaced
2/4/06 – 28,500 miles - ?
Transmission failure again – will not shift into Reverse, hard to shift into 1st gear
02-06-06, 12:50 AM
| | Cadillac Owners Connoisseur Cadillac(s): Lemon Law'd '05 V | | Join Date: Feb 2005 Location: Long Island, NY | | | Re: Report diff failures! That must have taken quite a bit of time, Chris. Thanks for your help.
-ace |
02-06-06, 02:12 AM
|  | Cadillac Owners Member Cadillac(s): 2006 CTS SPORT | | Join Date: Nov 2005 Location: Niagara on the Lake, Canada Age: 50 | | | Re: Report diff failures! Quote: |
Originally Posted by wildwhl True, they might. There have been substantial CTS/SRX failures too (whining only that I know of) but I'm doubtful those complaints are there. | I have an 06 3.6L Sports package Cts with 3000 klms on it. Took mine into the dealer last week to complain about a fluid leak from the rear end. They checked it out and said the rear diff. seal is leaking and they would order a new one in for me. Is my problem worthy of a complaint,( would it help you guy's out at all), or should I hold off and see if I have any other problems with it?
Chris |
02-06-06, 02:49 AM
|  | Cadillac Owners Member Cadillac(s): 05 maggied CTS-V, 03 maggied Z06 | | | | | Re: Report diff failures! Being in Canada, your complaint might not carry any weight, but give it a try. |
02-06-06, 03:01 AM
Originally Posted by heavymetals Being in Canada, your complaint might not carry any weight, but give it a try. | Ok, I will give it a shot, you never know. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
