| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Report all diff problems
02-06-06, 03:16 AM
| | Cadillac Owners Fanatic | | Join Date: Dec 2004 Location: san diego county | | | Re: Report diff failures! I just filed a complaint about the whine. My diff has not failed yet with 22,000 miles on it. It has always whined and the dealer told me that was normal. I DONT THINK SO! |
02-06-06, 03:35 AM
|  | Cadillac Owners Member Cadillac(s): 05 maggied CTS-V, 03 maggied Z06 | | | | | Re: Report diff failures! Quote: |
Originally Posted by wicked v I just filed a complaint about the whine. My diff has not failed yet with 22,000 miles on it. It has always whined and the dealer told me that was normal. I DONT THINK SO! | Like I said, YOU DON"T HAVE TO HAVE A FAILURE TO FILE A COMPLAINT!
You do need a VIN#.
__________________ I am so expensive I can't even afford to hire me.... |
02-06-06, 09:06 AM
|  | Cadillac Owners Connoisseur Cadillac(s): ~2004 CTS-V, 2006 STS-V, 2007 Escalade~ | | Join Date: Apr 2005 Location: Boston, MA | | | Re: Report all diff problems >Curious - some will report under 04, 05 or 06...will they compile them together for the platform, or should we all just say report them as 05's?
Report what year you have, keep it accurate. |
02-06-06, 02:38 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 05 Maggied V Black/Black | | Join Date: Oct 2005 Location: Where the Army sends me | | | Re: Report all diff problems Done |
02-06-06, 04:36 PM
|  | Super Mod Cadillac(s): 07 STS-V Platinum | | Join Date: Aug 2003 Location: North Coast, OH Age: 43 | | | Re: Report all diff problems submitted......
F |
02-06-06, 09:07 PM
|  | Cadillac Owners Fanatic | | Join Date: Sep 2005 Location: Long Island, NY | | | Re: Report all diff problems Just submited mine, 06 diff already started with the wine &
leaking on the right side WTF, its only been 2 weeks @ most!!!!: |
02-07-06, 12:31 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 04 CTS-V R.I.P. | | Join Date: Apr 2004 Location: Downey,CA Age: 23 | | | Re: Report all diff problems Just submitted my complaint. |
02-07-06, 01:16 AM
| | Cadillac Owners Member | | Join Date: Oct 2005 Location: So. Cal | | | Re: Report all diff problems Submitted complaint. |
02-10-06, 06:13 PM
| | Cadillac Owners Enthusiast | | | | | Re: Report all diff problems There's not even 30 on that list, there has to be more. |
02-10-06, 06:33 PM
| | Cadillac Owners Enthusiast | | | | | Re: Report all diff problems Repost master |
02-13-06, 12:57 AM
| | JRoller Cadillac(s): '04 CTSV | | Join Date: Oct 2005 Location: Las Vegas, NV | | | Re: Report all diff problems Submitted |
02-14-06, 08:15 PM
| | Cadillac Owners Member Cadillac(s): Escalade | | Join Date: Oct 2004 Location: Houston Age: 32 | | | Re: Report diff failures! What did GM do for you? or did I miss that. I'm having similar problems and have requested that GM buy my car back. Quote: |
Originally Posted by CVP33 Tonight I reported the information below to the NHTSA. If this helps even one V owner I've done my best.
2005 Cadillac CTS-V
VIN 1G6DN56S25013XXXX
Purchased 12/16/2004
Reported to NHTSA Complaint # 10149XXX
4/11/05 8,367 Miles 1 day out of service
Rear End Failure
4/28/05 9,664 Miles 5 days out of service
Rear Bushing Failure
Rear End Failure
5/5/05 9,720 Miles 1 day out of service
Rear End Failure
Wheel delivered from factory will not balance no sign of damage
7/25/05 15,732 Miles 4 days out of service
PCM recall #05544 dealer unable to reprogram
Rear end hops wildly in rainy or slick roads when accelerating
Hard shifting into 1st gear
Rear end whine
Drive line clunk
Parking Brake goes to floor and wont stop car
Rear End Failure
Dealer replaced rear differential and did not add friction modifier, claimed CTS-Vs do not need later determined this was incorrect
8/29/05 17,372 Miles 22 days out of service
Rear end grinding Friction modifier added
Transmission rebuilt
Replaced Pressure Plate
Replaced Clutch TSB 05-07-31-001
Rear End bushings installed to reduce wheel hop TSB 05-04-114-001A
Navigation system replaced after all buttons were peeling
PCM Recall performed
10/6/05 18,990 Miles 0 day out of service
Navigation System not programmed properly by dealership returned for repair
11/5/05 22,151 Miles 0 day out of service
Replace all center caps peeling
1/2/06 27,171 Miles 10 days out of service
Rear End Failure
Radiator Failure TSB 05-06-02-005A
Sun Visor replaced due to peeling
1/19/06 27,538 miles 6 hours out of service
PCM removed and replaced at ASM's request
1/26/06 28,000 miles 2 hours out of service
Navigation System removed and replaced
2/4/06 28,500 miles - ?
Transmission failure again will not shift into Reverse, hard to shift into 1st gear | |
02-14-06, 08:20 PM
| | Cadillac Owners Member Cadillac(s): Escalade | | Join Date: Oct 2004 Location: Houston Age: 32 | | | Re: Report all diff problems Diff problems, at 21,919 miles |
02-14-06, 09:40 PM
|  | Differential Slayer | | Join Date: Feb 2004 Location: Chesapeake, VA Age: 43 | | | Re: Report all diff problems GM did nothing. Informed me that I should sue them. In VA I can be counter sued by GM for damages. Also, the total amount I can get is current mileage divide by 100,000 times purchase price. You can also get additional damages that you can prove such as lost time from work, stained driveway (leaking diff), etc. In my case trade in was a better deal than a buyback or having to sue.
And for the record my V currently sits at the Chrysler dealer as they "work it out" with GM to replace the transmission (its second). I'd love to hear that conversation.  |
02-15-06, 02:27 AM
|  | Cadillac Owners Master | | Join Date: Mar 2004 Location: Reno, NV | | | Re: Report all diff problems CVP, you V/diff killer you  | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
