Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Custom Wheel Spacers for the V
Old 01-13-06, 12:44 PM
View detv's Photo Album
Casino Cash: $250
Has anyone installed custom wheel spacers on their V? If so, where did you get them? I've called a few places and had no success. I'm looking to extend rear wheels additional 11.0 -13.0 mm and frt 0.80mm - 1.0mm.
  #2 (permalink)
Old 01-13-06, 01:10 PM
lasstss's Avatar
View lasstss's Photo Album
Casino Cash: $510
Re: Custom Wheel Spacers for the V
Any local machine shop can carve you up a set from aluminum. Its a no brainer. 70.3mm ID with a 6 hole 115mm " BC.
  #3 (permalink)
Old 01-13-06, 07:15 PM
StealthV's Avatar
Cadillac(s): Twin-Turbo Bimmer/C6Z06 Hunting...
View StealthV's Photo Album
Casino Cash: $3517
Using ~7 mm spacers on the rear right now. As Lasstss mentioned, they are easy to make.
  #4 (permalink)
Old 01-13-06, 10:41 PM
greggbat's Avatar
Cadillac(s): '05 CTS-V (sold), '10 Jaguar XF-R
View greggbat's Photo Album
Casino Cash: $450
What is the OD and the diameter of the 6 holes? Sounds like a quick waterjet job.
  #5 (permalink)
Old 01-13-06, 10:50 PM
Cadillac(s): 2004 V
View Dreamin's Photo Album
Casino Cash: $400
http://www.wheelspacer.com/ These guys make custom spacers... they did Wildwhl's & Lawfive's. So they'll have the specs for the V in their system...
With 11 - 13mm in the rear, you'll need longer wheel studs. The biggest you can safely go w/stock studs is ~0.25 inches.
I've never heard of a 1mm spacer... i'm not sure if anyone will make you one of those.
There is a company that makes 'off-the-shelf' 1/4" spacers (non-hubcentric)... that's where I got some for testing... but i cant remember their name
I thought you had stock wheels
  #6 (permalink)
Old 01-14-06, 12:25 AM
Slywun's Avatar
Redline V
Cadillac(s): CTS-V
View Slywun's Photo Album
Casino Cash: $1428
Novice here........What is the purpose of spacers? Would it cause premature wear of the hub/axle bearings?
  #7 (permalink)
Old 01-14-06, 12:50 PM
lawfive's Avatar
SUPERBOWL Champions. Just saying.
Cadillac(s): 560 HP Blitzburgh Edition CTS-V
View lawfive's Photo Album
Casino Cash: $1132775
Keeps aftermarket or modded wheels from rubbing against the control arms.
{ This message is composed of 100% recycled sub-atomic particles. No trees were harmed in the posting of this message. However, billions of electrons were temporarily inconvenienced.
  #8 (permalink)
Old 01-14-06, 01:16 PM
Casino Cash: $250
Thx guys. I will try to find some.
I do have stock rims but want the wheels flush with the body. Especially the rear wheels are reset within the wheel-wells a little to much for my tastes.
  #9 (permalink)
Old 01-16-06, 04:11 PM
Casino Cash: $250
Hi Guys:
I talked with "Fred" at Wheel Spacers.com and he said he's 69 years old and can barely remeber his name. He said I would need to confirm the following:
Hub size dia.
Bolt size
Stock wheel stud size.
The ID 70.3mm is clear but 115mm is to the center of bolt?
thx
  #10 (permalink)
Old 01-16-06, 08:18 PM
Cadillac(s): 2004 V
Casino Cash: $400
PM wildwhl... he had his spacers made by wheelspacer.com
  #11 (permalink)
Old 01-16-06, 09:37 PM
wildwhl's Avatar
Cadillac Owners Master
View wildwhl's Photo Album
Casino Cash: $415
Well...I don't know the answers to those questions.
When Fred made mine he insisted on figuring this stuff out for himself. He also sated that the thinnest he could make them was about .2" (which mine are). So, I don't know the numbers because Fred figured them out for me!
Maybe if he scratches his head a little longer.
He isn't cheap, but the spacers are perfect.
WW
  #12 (permalink)
Old 01-16-06, 10:09 PM
StealthV's Avatar
Casino Cash: $3517
Grapped the calipers and measured the dimensions of Fred's spacers that I'm running (thanks WW):
Thickness = 5.25 mm
OD = 154.5 mm
Bolt Circle = 115.0 mm
Stud ID = 12.7 mm
Hub ID = 70.6 mm (with 3 mm x 45 degree chamfer)
As Dreamin mentioned - this spacer is about max thickness for stock length studs in the rear. This 5.25 mm spacer will get the desired flush look of the rear wheels.
  #13 (permalink)
Old 01-17-06, 01:43 AM
wildwhl's Avatar
Casino Cash: $415
Agreed. I nearly stripped (may have stripped) a stud at last tire change when torquing with these spacers in place (yes, I'm lame, I'm running the spacers with the winter tires/wheels too - looks cool IMHO). Careful with the thickness.
detv - why are you wanting to go so far in the back (1/2" or so) and what is the point of the paper shim in the front?
  #14 (permalink)
Old 01-19-06, 06:52 PM
Casino Cash: $250
Thanks guys!
Well I made a little miscalcultion with thinkness in rear. I measured the inset of the wheel vs. top of fender and came ~ .5 inch. However, I measured post four wheel alignment. For "some reason" my tech showed me my rear end had major misalignment. Since I never had an alignment before I realized a valet driver either ran over a curb backwards at 40mph, or it was the wheel hop.The main point being the pitch of rear tires have changed and it's less then .5 inch.
As for the sand paper in frt wheels - well I'm just anal.
  #15 (permalink)
Old 01-19-06, 07:57 PM
chiro444's Avatar
View chiro444's Photo Album
Casino Cash: $250
How much do the spacers run?
Tags: , ,
custom, spacers, wheel
Censor is OFF
