vibration problem /rattle clicking noise
Results 1 to 10 of 10
2004-2007 Cadillac CTS-V General Discussion Discussion, vibration problem /rattle clicking noise in Cadillac CTS-V Series Forum - 2004 - 2007; Ok so last night when coming home I made a left hand turn n all of a sudden a weird ...
    lx5.0 is offline Cadillac Owners Member
    Jun 2013
    30
    72
    Ok so last night when coming home I made a left hand turn n all of a sudden a weird rattle /clicking noise came out of no wer , it sounded like it was an engine rattle but I would rev engine and no rattle from engine . The engine was fine the clicking would always come out when accelarating and go away when I get speed . So I left it for the morning and drive it around and took off from a stop and clicking rattle noise disappeared but I got a bad vibration from rear when I accelerate I lifted car and noticed drive shaft had grease all over it where it connects at rear end I would mov drive shaft and it makes a funny noise like it's loose. So I tested car on Jack stands in the air and no vibration I put it down drove it around and vibration dussapeared but click rattle noise came bak drove it for a while and little by little vibration is coming bak , so is this issue I'm having a drive shaft issue , is the grease I found in rear a bad sign .
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    Re: vibration problem /rattle clicking noise
    It sounds like you at least need a pinion seal (see attached) and possibly some additional fluid in the differential. Taking care of that may, or may not, address the vibration issue.
  3. #3
    Jun 2013
    30
    72
    Well I don't think it a fluid from the diff it looks like grease the same way like when a cv shaft boot tears that's how it looks and then I grab drive shaft and it sounds loose inside that rear piece that connects to diff that has like a rubber piece that pushes in and out Wat is it made of or Wats inside
  4. #4
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    The driveshaft (aka propeller shaft) cv joint is not serviceable the only remedy in the Service Manual for the loss of its lubrication is the replacement of the driveshaft. See attached. There have been some aftermarket attempts to rebuild these diveshafts, but I have not keep current with their progress.
  5. #5
    Jun 2013
    30
    72
    So I think y problem is going to be the drive shaft then that sux that their not repairable and cost so much anybody know of a place to get another for a low price
  6. #6
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    Luke Butler
    703-647-8670
    lbutler@lindsaycadillac.com
  7. #7
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,711
    Quote Originally Posted by lx5.0 View Post
    Hello lx5.0,
    I can see how this could be concerning. I apologize for the inconvenience this has caused you. It appears you are just gathering feedback from the forum members but if you would like our assistance getting your vehicle into the dealership please let me know. Just send a private message with your VIN, contact info, mileage and dealerships info.
    Katie O.
    Cadillac Customer Care
  8. #8
    Jun 2013
    30
    72
    http://www.cadillacforums.com/forums...need-help.html
    I found my 6 Allen bolts loose think that's y my drive shaft spit out all the grease and is clicking and vibrating bad now i even tied it down but vibration still Ther even worse and clicking once a while
  9. #9
    Jun 2013
    30
    72
    Will a drive shaft from an 05 v fit an 07 is it the same thing
  10. #10
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    Affirmative.
  11. Remove Advertisements
