| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: I am trying to get complete custom rear for V from:
12-01-05, 06:28 PM
|  | Cadillac Owners Connoisseur | | Join Date: Dec 2003 Location: Ellicott City | | | Re: I am trying to get complete custom rear for V from: Quote: |
Originally Posted by Flyboy Okay.....just got back from DTS in Warren, Michigan. Talked with one of their techs for about 30 minutes. Other than "cryogenics", there's not much he can recommend for us at this time. Big problem is that no matter who comes up with a "fix" or an improvement, how many ACTUAL "takers" will there be? In other words, since there are so few "V's" out there, a company may never recover the R and D involved with such a project. In any event, I told him, I still have my old diff and would he like to take it apart and analyze it? He said absolutely, so I'm taking it back to him today. I'll post the results of his teardown when complete. Sorry I don't have better news. He did say that some of the Corvette guys are doing that cryogenic stuff and having pretty good luck making the diffs last longer....Stay tuned for more | Unfortunately, they can cryo and heat treat till the cows come home. The drivers side cover/bearing/shaft mount is still less than 1/8" thick. Its just too thin to prevent movement. Good luck. |
12-02-05, 12:48 PM
|  | Cadillac Owners Master Cadillac(s): '05 CTS-V | | Join Date: Jul 2004 Location: Elkridge, MD Age: 37 | | | Re: I am trying to get complete custom rear for V from: Quote: |
Originally Posted by lasstss Unfortunately, they can cryo and heat treat till the cows come home. The drivers side cover/bearing/shaft mount is still less than 1/8" thick. Its just too thin to prevent movement. Good luck. |
Marty, is this still the case with the new '06 part?
Would it be worth it to cryo treat an '06?
-Chris |
12-02-05, 01:47 PM
|  | Piaggio Pilot | | Join Date: Apr 2005 Location: Scottsdale, Arizona | | | Re: I am trying to get complete custom rear for V from: Chris,
Good question....I'm wondering the same thing?????
Marty will probably have an answer to this..... |
12-02-05, 02:38 PM
|  | Cadillac Owners Member | | Join Date: Dec 2004 Age: 39 | | | Re: I am trying to get complete custom rear for V from: I'll have to keep you guys posted on mine also, gonna be a custom 12 bolt rear. Lots of other stuff has to be done first, have a 402 going in, FAST intake, D-1SC Procharger, then the car has to go to Houston for the rear. I'll update as often as I can.
Mike |
12-02-05, 02:45 PM
Marty will probably have an answer to this..... | Well, its the same BUT all of the ribbing on the case was made thicker or was extended, including the cover. I doubt they actually changed its physical thickness.
The Aussies are not dead yet. My contact is on vacation so Im waiting. Unlike us Americans, it seems the foreigners have unlimited 'holidays'.....
I have it from a reliable source that the 06 half shafts are beefier!  |
12-02-05, 03:12 PM
|  | Piaggio Pilot | | Join Date: Apr 2005 Location: Scottsdale, Arizona | | | Re: I am trying to get complete custom rear for V from: Marty....
Thanks for chiming in here. I like what Mike Smith is thinking about also. My guess that sometime during '06, someone will have a fairly strong "permanent" (if I may use that word) fix for the diff problem.
C Ya'
Jimmy |
12-02-05, 04:22 PM
|  | SUPERBOWL Champions. Just saying. Cadillac(s): 560 HP Blitzburgh Edition CTS-V | | Join Date: Sep 2004 Location: Steeler Nation | | | Re: I am trying to get complete custom rear for V from: Quote: |
Originally Posted by MSMITH I'll have to keep you guys posted on mine also, gonna be a custom 12 bolt rear. Lots of other stuff has to be done first, have a 402 going in, FAST intake, D-1SC Procharger, then the car has to go to Houston for the rear. I'll update as often as I can.
Mike
05 Platinum V, Maggie, 2.8 pulley, Billy Boat headers & exhaust w/x-pipe, More CAI, AFR 225cc Heads, 224/227-.563/.569 114 LSA cam, BMR anti-wheelhop kit, SPEC Stage 3 Clutch, Custom Tune, B&M Ripper Shifter, 500rwhp/440rwtq | Wow! Question: I've got a Maggie 2.8 & no headers. I'm making 482 RWHP/452 RWTQ. I've been thinking about what to do when I break warranty, and it's been looking like cam/heads/headers (and maybe dry nitrous  ). But I see that your numbers with cam/heads/headers aren't substantially better than mine (I'm not trying to start anything here...), and I'm wondering whether all that expense would show up as power gains for me.
My understanding (limited at best) is that on our car less restrictive heads need less restrictive exhaust headers for any benefit, and that Maggie users will have to reduce their pulley size yet again to get the boost back up (I'm surely no expert on what's going to happen if you add significant volume to the combustion chamber...). Have you done that? In other words, are your numbers maybe not as good as they could be 'cause maybe the Maggie is only making 3+ pounds or so?
Or is this as good as it gets with this combination on the top end of the engine, so I can just save my money?
__________________ { This message is composed of 100% recycled sub-atomic particles. No trees were harmed in the posting of this message. However, billions of electrons were temporarily inconvenienced. |
12-02-05, 09:03 PM
|  | Baddass V Lover | | Join Date: Jan 2005 Location: Newark, Ohio Age: 48 | | | Re: I am trying to get complete custom rear for V from: Well, the drifting rear is not hooking either, don't forget.
But, having been intimate with both, I would say that a cryo treatment of the '06 diff would be good money spent, and yes its visibly thicker everywhere on the case. |
12-07-05, 04:00 PM
|  | Cadillac Owners Member | | Join Date: Dec 2004 Age: 39 | | | Re: I am trying to get complete custom rear for V from: Blitz how much $ are they talking about for the one you're looking at doing? Mine's gonna be a 12 bolt w/independent suspension but gonna cost a shitload. Just wondering...
Mike |
12-07-05, 06:03 PM
|  | Cadillac Owners Fanatic | | Join Date: Oct 2005 Location: Miami, Fl. | | | Re: I am trying to get complete custom rear for V from: hey, when i first read a 12 bolt i tought of a typical 12 that goes in a z28.
But, yours a independent unit? VERY, VERY intersting....any more info or where i can see for myself.
thanks!! |
12-07-05, 06:05 PM
|  | Cadillac Owners Member | | Join Date: Dec 2004 Age: 39 | | | Re: I am trying to get complete custom rear for V from: Gonna be a one off, Brian "Madman" Jeffery, www.madmanandcoracing.com.
Mike |
12-07-05, 06:13 PM
|  | Cadillac Owners Fanatic | | Join Date: Oct 2005 Location: Miami, Fl. | | | Re: I am trying to get complete custom rear for V from: wow, that rx-7 is so badass!!!! Took the swap idea righ of my head..though its not the first i have seen!!!
good luck on that setup, if you wish, here is my email if you want to rely and pricing info? arg_z28@yahoo.com |
12-07-05, 06:17 PM
|  | Cadillac Owners Member | | Join Date: Dec 2004 Age: 39 | | | Re: I am trying to get complete custom rear for V from: Not even sure exactly how much atm, just know it's going to be high as hell. Right now the engine is still being built then the Procharger has to go on. Car likely won't go to Houston for the rear until late next month.
Mike
On a side note, we have 2 '06 V's on the lot atm, one Infrared, one Black. |
12-07-05, 06:34 PM
|  | Cadillac Owners Fanatic | | Join Date: Oct 2005 Location: Miami, Fl. | | | Re: I am trying to get complete custom rear for V from: hmmm...
how about a diff switch-a-ru? |
07-23-09, 09:01 AM
|  | Cadillac Owners Member Cadillac(s): Cadillac CTS-V | | Join Date: Jul 2008 Location: Lusby Maryland | | | Re: I am trying to get complete custom rear for V from: Quote:
C Ya'
Jimmy | I was searching the forum to see if anyone had ever tried cryo treating a diff and this post made me laugh. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
