Where is water temp sending unit located?
Results 1 to 12 of 12
2004-2007 Cadillac CTS-V General Discussion Discussion, Where is water temp sending unit located? in Cadillac CTS-V Series Forum - 2004 - 2007; After they replaced my defective battery today, my water temp will only read "---". All other readouts on the tach ...
    ntechnic's Avatar
    ntechnic is offline Cadillac Owners Fanatic
    May 2005
    261
    After they replaced my defective battery today, my water temp will only read "---". All other readouts on the tach read just fine. So I'm thinking the dealer tech may have knocked a wire off the sender or something. I'd just as soon look for it as them.
    Anyone know where it is? Or if any of it's wires are near the battery?
  2. #2
    Barak is offline Cadillac Owners Fanatic
    Mar 2005
    Ontario, CA
    490
    Re: Where is water temp sending unit located?
    The check engine light should be on if the engine coolant temperature (ECT) sensor is disconnected. If the check engine light isn't on, then something may have gone wrong with the instrument cluster. Maybe one too many voltage spikes from changing the battery fried something in the cluster.
  3. #3
    ntechnic's Avatar
    May 2005
    261
    Thanks, I guess it's back to my dealer. The security system light keeps coming on at random now too. Sigh.
  4. #4
    10secTy's Avatar
    10secTy is offline Cadillac Owners Member
    Automobile(s): none
    Feb 2007
    60
    What did this turn out to be? I am having the exacty same thing happen on my V.
    thanks
    Nolan
  5. #5
    wildwhl's Avatar
    wildwhl is offline Cadillac Owners Master
    Mar 2004
    Reno, NV
    5,496
    The temp sensor is just below the #1 spark plug, by the air box. Easy to knock off/damage the wires if you've done a CAI kit or pulled the stock airbox for any reason...and the result will be --- without any CEL (but you might have some other strange behaviors if the connection is intermittent!)
    WW
  6. #6
    10secTy's Avatar
    Automobile(s): none
    Feb 2007
    60
    I hooked up my hptuners and can see the engine temps working find at the pcm. I can unplug it and see it drop to -30 on the scanner but the gauge reading stays at zero. I think my gauge cluster might have took a dump.
    I need a Tech2 so I can hook up and test to make sure the gauge still sweeps.
    Its funny because I was driving the car and saw the temp gauge just drop to zero all a sudden. I could see if I started it and it did not work. Seems funny it died driving along.
    Nolan
    Quote Originally Posted by wildwhl View Post
    WW
  7. #7
    Black Sunshine's Avatar
    Black Sunshine is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS-V
    Nov 2006
    Moultrie, GA
    56
    838
  8. #8
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Quote Originally Posted by Black Sunshine View Post
    Imaginary points to you for posting a pic. GOOD SHOW!
    -Chris
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
  9. #9
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    My car does not have that green circular wire on it!!
    LOL
  10. #10
    Late Apex's Avatar
    Late Apex is offline Cadillac Owners Member
    Nov 2012
    Bay Area, CA
    11
    This just happened to me today, and i'm a tad stumped at what is actually/or has actually failed if anything? Intermittently the temp gauge @ KOEO with door open or if the vehicle was off for a short time would operate normally for 10-15 seconds then the physical gauge and digital gauge will fall off and stop reading temp. Anyone with any insight or has delt with this and has a resolution to the issue I would greatly appreciate it. It really irks me to not be able to track/see coolant temp.
  11. #11
    Silencertk is offline Cadillac Owners Member
    Automobile(s): CTS-V V1
    Oct 2012
    Germany
    36
    97
    My temp sending unit went out couple of days ago as well. No gauge no digital temp readout. And engine hot - ac off message. Disconnected the battery, wiggled the wires tried everything. Went looking for a new sending unit - the car stayed parked for 2 days.... what do you know - started working again.
    May not apply to you - but if its not your daily driver - let it sit for a day or two. And see what happens.
  12. #12
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,201
    Intermittent readings from engine-related gauges are often caused by oxidation of the engine harness-related grounds. This oxidation is not readily apparent because it does not look like the corrosion that can develop on battery terminals. The fix is to pull the grounds and freshen them with some abrasive material - star washers can also help.
    The critical grounds on the CTS-V include: the negative battery terminal; the ground located just beneath the hood stick mount; the ground located on the back of the passenger-side cylinder head; and the two grounds located on the back of the driver's-side cylinder head. If you keep these ground s fresh, you can avoid "ghosts" in your gauges. (This actually applies to most modern computer controlled cars.)
    See attached.
  13. Remove Advertisements
