Quite Possibly The Best "Dry" Tire On The Market
Results 1 to 12 of 12
2004-2007 Cadillac CTS-V General Discussion Discussion, Quite Possibly The Best "Dry" Tire On The Market in Cadillac CTS-V Series Forum - 2004 - 2007; http://www.tirerack.com/tires/tires....ID=C13674x017&...
    steve711's Avatar
    steve711 is offline Cadillac Owners Fanatic
    Jul 2004
    Ft Collins Co
    42
    444
  2. #2
    Dreamin is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 ATS-V
    Feb 2004
    Calif.
    2,261
    Re: Quite Possibly The Best "Dry" Tire On The Market
    That's a track tire... can be driven to and from the track... but they're not going to last on the street.
    As far as track tires... Hoosiers are the Best "Dry" Tire... MHO.
  3. #3
    ace996 is offline Cadillac Owners Connoisseur
    Automobile(s): Lemon Law'd '05 V
    Feb 2005
    Long Island, NY
    1,241
    Best Track - Hoosier
    Best Street- Falken Azenis 615
    These opinions have been proven at countless track events and autocrosses Nationwide.
    The Pilot Sport Cups are a top notch tire that may trade ultimate grip with a longer life than Hoosiers.
  4. #4
    Vrocks's Avatar
    Vrocks is offline Cadillac Owners Connoisseur
    Automobile(s): CTS-V
    Feb 2004
    1,192
    Quote Originally Posted by ace996
    Hey Ace996,
    Do you use the Falken Azenis 615's on your V? I'm looking for new tires and I haven't heard anything about the Falkens.
  5. #5
    Devil_concours is offline Cadillac Owners Connoisseur
    Jan 2003
    Alexandria, VA
    34
    3,684
    Quote Originally Posted by Dreamin
    kumhos are pretty good too
  6. #6
    CVP33's Avatar
    CVP33 is offline Cadillac Owners Master
    Automobile(s): '04V, '05V, '06SRT8, '10V, '13ZL1, '12 V, '16 Z06 SC757
    Feb 2004
    Killer of diffs 7X
    51
    6,441
    I picked up a set of Falken Azensis of ebay cheap. I mounted them yesterday. 255/45/18. I expected them to be wider, but they are actually taller and not really wider at all. Grip is ok, not great. Tires are new so I'll reserve final judgement for another time. These definitely fill the wheel well better. And no rubbing.
  7. #7
    Feb 2005
    Long Island, NY
    1,241
    Vrocks,
    No, I don't currently run the Falkens on the V. I've used them on my MR2Spyder and they are phenomenal. I've done autox runs in a friend's BMW 325 with the new Falken 615s and were totally blown away. They hold a line like no other street tire I've ever driven and severely close the gap between street tires and race-compound rubber. If I keep the V past the winter, I'll mount the 255s in the Spring.
    CVP33,
    Just wait till you wear off the mold release... If you are running the older 215s, they wear very well for the level of grip/level of cost. Keep in mind, they don't like to get too hot, many autocrossers use a weed sprayer with cold water to bring down the temps between runs on hot days.
    For the money, and even with the cost not factored in, the Falkens are a top notch tire that uses a very stiff sidewall that is a great alternative to our runflats. Give them some time, and then please let us know your thoughts.
    Good luck.
  8. #8
    v-Power's Avatar
    v-Power is offline Awaiting Email Confirmation
    May 2005
    Dayton, OH
    47
    What else would you consider?
  9. #9
    Shinkaze is offline Cadillac Owners Fanatic
    Atlanta, GA
    331
    FWIW I used to daily drive R-Compound rubber on my Trans Am. All were horrid in the rain and averaged about 3,000 miles of tread life. (you can run them to 10K, but after 3K they're no better than a Max performance tire)
    Kuhmo Victoracer Autocross tire
    Great tire, good feedback and easy to handle. I got about 3K out of this tire.
    Yokohama A032R
    DO NOT BUY THIS TIRE. Ever hear a monster truck? That's what your tires sound like with these beasites on. They afford great grip, but after installing them I had to pull over and make sure something wasn't broken on the car it was making so much noise. Hell you could even hear the tire noise over my Exhaust cut-out...that's loud.
    BFG Drag Radial 315/35 R17
    Don't drive this one on the street. Maybe smaller sizes aren't as dangerous, but the 315/35 R17 tends to sidestep in traffic for no particualr reason. I would equate the feeling of this tire to the sensation of having 4 wheel steering, with the steering wheel to the rear tires being controlled by CB radio.
    Nitto Drag Radial
    Got about 10K useable life from this, good tire, more or less feels like a street tire but isn't nearly as sticky as other tires in the market.
    Anyhow, be warned R-Ompound tires are designed for the track, which is both good and bad. They Fling rubber onto your body panels, pick up rocks, generate a lot of noise and drive harshness into the cabin and last about as long as an oil change.... God help you if you hit a pot-hole they're made so light and flimsy the belts seperate easy. In the rain they're useless, heck even a hummid day will make driving the car akin to a roller coaster ride.
    All that said, if you have the tollerance for abuse of an 18 year old, play joe-hero on the streets and only drive on super dry days, then R-Compund tires are a hoot, but maybe after turning 30 I turned into a grumpy old codger, `cause the reality is that, at the point these things are worthwhile beyond a max performance tire, you're allready endangering yourself what the street can afford you.
    -Adam
  10. #10
    Silver Baron's Avatar
    Silver Baron is offline Cadillac Owners Fanatic
    Automobile(s): 2
    Feb 2004
    Canada
    381
    I hear you. I am 45
    What Falken 615 do you suggest? They don't make stock size 245/45/18.
  11. #11
    Atlanta, GA
    331
    Quote Originally Posted by Silver Baron
    I hear you. I am 45
    I'd give a CTS-V owner the same advice I give anyone looking for a decent performance tire. Ditch the Run Flats, get a tire repair kit, and buy the best "Max performance" Street Tire that will fit your car (Like a BFG G-Force KD, Pilot Sport, etc). What you loose in at the limit adhesion, you'll happily take in real world civility. As someone that has been through ~5 sets of R-Compund tires on street cars, I can say I now understand why track tire are for the track and street tires are for the street.
    FWIW I blame R-compund track tires for (3) blown differentials, and two full sets of shocks destroyed in my TA.
  12. #12
    Feb 2005
    Long Island, NY
    1,241
    255/40/18 on all four corners. Due to the V's weight, any additional rubber will lead to better performance and tire life. The sidewall will be a little smaller, but not by much.
    Again, for the money, you cannot find a better STREET tire than the Falkens. They are known to have a stiff sidewall, not as much as a run flat, so you should have some peace of mind in regard to added safety for your rims.
    If there wasn't the Falken, I'd go with a Kumho street tire. They're cheap, good performance, and wear well. That'd be my number two choice. In regards to the major manufacturers like Michelin, Bridgestone, ect....the prices they charge for their top rubber is outrageous. There is most of the performance and wear characteristics available cheaper, but you don't have to pay for F1 sponsorship....
  13. Remove Advertisements
