Drive-shaft to Differential Bolts ?
Results 1 to 6 of 6
2004-2007 Cadillac CTS-V General Discussion Discussion, Drive-shaft to Differential Bolts ? in Cadillac CTS-V Series Forum - 2004 - 2007; What are the specs for the bolts that hold the drive-shaft to the rear differential ? (I believe there are ...
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    What are the specs for the bolts that hold the drive-shaft to the rear differential ? (I believe there are 6 of them.)
    Next time they come out, should I upgrade to a higher grade bolt ?
  2. #2
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    30
    979
    Re: Drive-shaft to Differential Bolts ?
    Quote Originally Posted by SevillianSTS View Post
    The OEM bolts should be more than sufficient for your needs. Make sure to put loctite on them if you ever remove and re-install them. The DSS CF 1 piece driveshaft uses similar bolts and calls for 57 ft/lbs.
  3. #3
    Aug 2005
    Northern IN
    1,006
    I've had them off a few times. I'd like to get some fresh ones in there. Kinda worried about spinning the allen wrench in the head.
  4. #4
    Mar 2010
    San Jose, CA
    30
    979
    Just buy another set of OEM bolts if you're concerned. They are more than adequate.
  5. #5
    Aug 2005
    Northern IN
    1,006
    Anybody have a part number ? I'd rather order them online than make 2 trips to my dealer.
    Thanks.
  6. #6
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
  7. Remove Advertisements
