New Rear Brake Pads - Backing Plate / Grease Question ?
Results 1 to 10 of 10
2004-2007 Cadillac CTS-V General Discussion Discussion, New Rear Brake Pads - Backing Plate / Grease Question ? in Cadillac CTS-V Series Forum - 2004 - 2007; So I'm putting new rotors and pads on the rear. I have a set of stock Brembo pads (came with ...
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    I have a set of stock Brembo pads (came with backing plates, and a copper looking grease)
    Where do I apply this grease ?
    Also meant to say, yes I did check the FAQ for this simple question, but did not see anything specific.
    Thanks.
  2. #2
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: New Rear Brake Pads - Backing Plate / Grease Question ?
    You put the grease on the back side of the pad then place the metal shim over it. Do NOT put grease on the wear surfaces.
  3. #3
    Aug 2005
    Northern IN
    1,006
    Quote Originally Posted by philistine View Post
    Thanks, ya I knew not to put slippery grease on the friction surface. LOL.
    Nothing on the other side of the shim ? Seems everywhere I read online they say to put it on the edges... but I don't see how it would ever stay on the edges for very long.
  4. #4
    fweasel's Avatar
    fweasel is offline Cadillac Owners Fanatic
    Aug 2013
    Chicago
    256
    Its used for anti-resonance, and really is only effective, IMO, between the pad back and the shim. I too have seen procedures call for something to be applied between the shim and caliper piston face on other cars, but have never done that because its a mess, attracts and holds more dust, dirt, and grime. I personally use the bright orange CRC discbrakequiet goop. If given time to set, it cures to more of a rubbery substance and works fine for street pad temp ranges. I used it the first time I loaded a set of track pads for an HDPE out of habbit and it didn't last long
  5. #5
    Aug 2005
    Northern IN
    1,006
    Thanks for all the input. I didn't know how critical this grease was.
    I'll admit, I had already put the pads on last night, and I did spread the grease between the shim and pad back. Just wanted to make sure I did it right. Haven't got it all the way back together cause I had to order new hardware; one of the pin retainers was broke.
  6. #6
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    The crc disc brake goop keeps the pads quiet by essentially gluing them in place and the grease keeps the pads from squealing as they move around.
  7. #7
    philistine's Avatar
    Sep 2011
    821
    Quote Originally Posted by SevillianSTS View Post
    No, nothing on the other side, that is it, just did a brake job on the 'V' with stock pads - no squeals and absolutely wonderful braking power!
  8. #8
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,299
    What do you guys do with pads that come with the shims already adhered to the back of the pads? Do you find that whatever they use to stick the shims on there provides the anti-squeal effect?
    Both the Raybestos front pads and the Stoptech rear pads I'm using now have shims already on them. I've been putting a little bit of grease on the outside of the shim, just where the pistons make contact - trying to use as little as possible to avoid the mess that was referred to earlier.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  9. #9
    fweasel's Avatar
    Aug 2013
    Chicago
    256
    I have not done any brake work on my V yet, but all of the Hawk street pads I used on my legacies, both OEM and brembo's calipers, had a shim bonded to the pad. I modified the OEM shim to fit the pad and prepped the surface between as usual. The pistons had to be fully compressed to fit the extra material, but my results were better than the one time I ran the pads w/o shims. The shim kept the entire assembly a little more tidy between services.
  10. #10
    Feb 2009
    Greenville sc
    45
    992
    Quote Originally Posted by fweasel View Post
    Gotta be careful when you start stacking shims. The brakes will expand a little when hot and can start to drag if you get them too tight.
    I also think this is one of the unofficial uses of the CRC. A lot of guys will dab it on the back of a pre-shimed pad and let the CRC essentially glue it into the brake piston so it won't move around. Kinda messy but I can't say that I've seen it cause problems either because it cleans up easily enough...
  11. Remove Advertisements
