Which bushings/mounts to inspect?
Results 1 to 7 of 7
2004-2007 Cadillac CTS-V General Discussion Discussion, Which bushings/mounts to inspect? in Cadillac CTS-V Series Forum - 2004 - 2007; Hey guys. I just got my 2005 CTS-V 2 weeks ago and have been reading up on the forums. Which ...
    -Ross- is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Mar 2014
    39
    3
    Hey guys. I just got my 2005 CTS-V 2 weeks ago and have been reading up on the forums. Which bushings/mounts should I inspect first? Which ones are the first to fail and what do I need to look for?
    At the present, I have a slight/faint clunkish ("ta-ta-ta") type of sound when I disengage the clutch between the 1-2 and 2-3 shift (probably have it during the other shifts, but at those speeds it's just not as noticeable).
    I have also noticed the engine comes to a kind of rumbley/shakey stop when turning the car off. Not terrible, but it's there. I assume this is a motor mount issue.
    Other than those 2 symptoms, the car seems pretty solid. No real vibration or anything while driving. The car had only 1 previous owner and is bone stock with 42k miles.
    Thanks in advance.
  2. #2
    austinls is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V, Black, Borla exhaust
    Jan 2014
    Austin, TX
    61
    48
    Re: Which bushings/mounts to inspect?
    There are many threads relative to V bushing issues. A search will keep you busy and be very informative.
    Typically, the rumbling when you turn the engine off is motor mount bushings. OEM mounts typically leak when bad, with brown residue showing on the side of the oil pan. Most of us have replaced OEM mounts regardless.
    Shifter bushings are also common to replace. I used Creative Steel bushings when I installed PISNUOFF's short shifter (a great product and great service from Brian).
    Trans mount/bushing is also common to fail.
    Front diff bushing is another common failure in V's.
    Enjoy your V. We all do.
    There are a couple Caddy dealers that are forum sponsors. Look to them for support and good prices on Cad parts (Rippy and Lindsay Cadillac come to mind). They are active on the forum and have ads/links.
  3. #3
    2007-V is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Oct 2013
    121
    Go ahead and plan to do the engine/trans/diff mount asap. You, and the car, will be much better off.
    the "ta-ta-ta" is likely the dual mass flywheel crap that will do that until you replace it, however that would be best done when it is clutch time.
  4. #4
    barrok69's Avatar
    barrok69 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Maggied
    Mar 2012
    Michigan
    271
    While you're under there you should also look at the front lower shock mount bushings. 40k on my car and they need replacing.
  5. #5
    Wingsfan4life's Avatar
    Wingsfan4life is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V Black Raven
    Aug 2011
    Brooklyn Center, Mn
    46
    232
    Plan doing every single one..starting with MM, Trans, Rear Diff, Shifter...work your way from there...depending on milage, and how hard you drive it will determine where to go next...have fun! And start looking at tires!
  6. #6
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Quote Originally Posted by barrok69 View Post
    There isn't such a thing. Are you talking about the lower control arm bushings?
  7. #7
    barrok69's Avatar
    Mar 2012
    Michigan
    271
    Quote Originally Posted by FuzzyLogic View Post
    I'm referring to the shock eye bushing. But they actually can't be individually replaced without installing a whole new shock unfortunately. I'm not sure how many other people have had this, but the lower shock bushing "integral to the shock" on my car is flattened/pushed out and pretty worn. I've had a small amount of impact harshness that I'm attributing to the pushed out/worn shock bushings.
    I've got new shocks and springs that I'll be installing soon so it won't be an issue for me, but for anybody else, sucks that you have to replace the entire shock for a worn out front lower shock eye bushing
  8. Remove Advertisements
