Brake Rotor question
Page 1 of 4 1234 LastLast
Results 1 to 15 of 56
Like Tree4Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Brake Rotor question in Cadillac CTS-V Series Forum - 2004 - 2007; I'm getting a little brake squeal from my right rear. I bought the car with 67k miles and I don't ...
    Mongopush is offline Cadillac Owners Member
    Automobile(s): 2006 CTS V
    Mar 2013
    41
    93
    I'm getting a little brake squeal from my right rear. I bought the car with 67k miles and I don't really know the service history. How do you know when to swap rotors along with new pads ? Can I measure them for a certain acceptable tolerance ?
  2. #2
    carlson_mn is offline Cadillac Owners Enthusiast
    Automobile(s): Platinum 06 CTS-V, kooks, magnaflow
    Jul 2012
    MN
    34
    636
    Re: Brake Rotor question
    yes there's a spec for minimum thickness before having them turned. I had the same problem and there was a large chunk of metallic material in the brake pad that I ground out.
  3. #3
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Brake rotors have their minimum allowable thickness cast into the outer edge. It can be really hard to spot if the rotor is rusted.
  4. #4
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,197
    See attached.
  5. #5
    Mar 2013
    41
    93
    Thanks guys, that's the info I was needing.
  6. #6
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    You'll also want to check for excessive runout.
  7. #7
    Mar 2013
    41
    93
    OK, so the dealer confirmed the rear rotors are shot,too worn down to turn. I've gone as long as I can with the squealing .They wanted $500 to replace the rear's, that's not including pads . I think I'm going to just order the Brake Motive setup and swap them myself . Any complaints on these from anyone who's used them before ? Or maybe a better alternative. I just street my car, no track time..so nothing too pricey.
  8. #8
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,197
    For what it is worth, Rock Auto has the AC Delco OES rear rotors for $66 a piece.
  9. #9
    Becker's Avatar
    Becker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 black with tan V
    May 2013
    31
    391
    ^^^ thats not bad..
  10. #10
    MostlyStock is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2006
    8
    brakeperformance .com has slotted dimpled rotors that are guaranteed not to warp for life for $215 a pair with free pads.. I was having warping problems went through 2 sets before buying these and have had no problems since...
  11. #11
    2007-V is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Oct 2013
    121
    Did that $500 include a full flush and pizza for the whole dealer.....twice?
    The braking systems on these cars are one of the easiest parts to service yourself, no reason to have someone else do it.
    I will let others speak to the aftermarket options as I am still rocking the OEM.
    BigDaddy-V likes this.
  12. #12
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,197
    Quote Originally Posted by MostlyStock View Post
    If you are suggesting that OEM CTS-V rotors are somehow prone to warping, I respectively disagree. (Setting aside the issue of whether the term "warp" is ever accurate when applied to brake rotors.)
    Guy.Seminerio likes this.
  13. #13
    Jeff James is offline Cadillac Owners Member
    Automobile(s): 07 V1
    Oct 2011
    Sonora, Ca.
    57
    97
    Be careful of those Rockauto ACD OES rotors. They are NOT the same as the OE pieces. As for the dimpled rotors (OK) with Free (Really??) Pads, you get what you pay for. Crossdrilledbrakes.com has drilled/slotted rotors with new pads for $275.00 Have had great luck with front V2 setup from them on the street with spirited(?) driving.
  14. #14
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    OEM rotors on ANY V are going to be very stout...
  15. #15
    jeffctsvmanw is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Aug 2009
    pittsburgh
    60
    17
    I got raybestos rear rotors from rock auto. Very nice quality, and use Hawk pads all around. Also replaced park brake shoes. During dyno run they got incinerated. But 360 rwhp was worth run!
  16. Remove Advertisements
