Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Cold Day Blues
    ImEpayne is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac CTS-V
    Feb 2013
    North Syracuse, NY
    27
    71
    Cold Day Blues
    Well I'm afraid these negative degree days here in Colorado are taking its' toll on my '06. Starting it up in the morning I have a serious power steering pump wine for about 20 seconds. I'm getting a chirp that won't go away from my water pump pulley. And my clutch goes down but comes back up very, very slowly for the first 3-5 minutes. None of these symptoms were present on warmer days, and once warmed up these symptoms go away (except for the pulley chirp).
    Are these symptoms I should worry about failures in the future or is it just having an attitude towards the weather. She's got about 93k on her and completely stock.
    Anyone else getting some funny things happening with this chill?
    Thanks,
    Eric
  2. #2
    BigDaddy-V is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V 04 LS6
    Mar 2013
    Wylie, TX
    412
    Re: Cold Day Blues
    I am nowhere near as cold as you but have noticed similar things when it gets cold enough down here in Texas. The clutch thing I noticed the other night when it was in the teens and that was the first time it felt a little off to me. and the only so far. I had a power steering whine once when it got very cold and noticed my fluid was low so put more in and it went away instantly.
    BDV
  3. #3
    Feb 2013
    North Syracuse, NY
    27
    71
    Re: Cold Day Blues
    I do have a slight PS leak, but the fluid is where it should be at. Hoping the pump isn't going bad...
  4. #4
    Redxped1 is offline Cadillac Owners Fanatic
    Automobile(s): 09 cts4 04 cts-v
    Jul 2003
    Bloomingdale IL
    30
    258
    Re: Cold Day Blues
    Mine did the same thing back in late nov when it started getting cold I parked it for the winter. Very happy i'm not driving it in this -20 windshields
  5. #5
    tophat is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Aug 2012
    minneapolis mn
    40
    120
    Re: Cold Day Blues
    Pulled the V out of the underground garage yesterday for an hr, temps -20 with -30-50 windchills, clutch pedal was pretty stiff as it was last year when I drove it thru the winter....I had the PS whine once last winter also.....I would not be too worried the cold weather does lots of funny things to every car, just make sure the fluids are fresh and you warm the car up before putting lots of stress on the motor and you should be fine.
  6. #6
    Feb 2013
    North Syracuse, NY
    27
    71
    Re: Cold Day Blues
    Thanks for the re assurance ladies and gents. Glad to see similar symptoms.
  7. #7
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,831
    Re: Cold Day Blues
    Was -16 this morning here, -4 right now, but my car is doing fine ... been sleeping for nearly three months now with battery tender hooked up.
    Don't envy you guys having to drive your Vs in this.
  8. #8
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    Re: Cold Day Blues
    I bet those cars are liking the taste of that cold air though.
    Wish I could get a drive with those temps on a dry salt free road.
  9. #9
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    Re: Cold Day Blues
    While it doesn't seem to really cause many problems overall, the power steering pump is working way to hard to push really cold, thick fluid through it when its this cold. The sound it's making cant be good for it in the long run but I'm more worried about blowing a steering rack seal than anything.
    Just bought my v and I've heard it make a little noise when it gets down in the 20s but it got down to 4 here last night and she raised hell for about 5 minutes before finally shutting up.
    That has sent me looking for a quick solution.
    By searching here I discovered GM makes a high performance PS fluid that is good in cold climates but since I live in the south, nobody close by stocks it. Went to advance and the only thing they had that was rated for low temps was some Prestone fluid made especially for Hondas that is rated to -40.
    Because I'm working 14 hour overnight shifts on a conveyor line install at a BMW plant here in town, I don't have the time or energy to sit through someone doing it for me and I'm to drained to do it right myself so I've been doing the "turkey baster" method for changing my fluid (using the cheapie Prestone stuff) so hopefully I won't blow the rack seals out of this thing trying to pump cold sludge through it tomorrow morning.
    I've sucked the reservoir dry 3 times now by stopping along the way during my commute and once again when I got to work. I'll do it a couple of more times when I go to lunch and by then I will have a cycled 3 pints through it.
    Desperate times call for desperate measures. I'll report on tomorrow to let you know if this worked.
  10. #10
    Aug 2005
    Northern IN
    1,006
    Re: Cold Day Blues
    Changed PS fluid last summer just because it was the last fluid that I hadn't flushed. Had no issues and it was only slightly brown. I felt a noticeable difference after flushing. Smoother feeling steering. I don't remember which line I pulled, you'd have to read up on that.
    -I just unhooked one of the lines, pushed a piece of clear tubing over it and ran it to a empty bottle. Plugged the port where the line went into the reservoir. Start the car for like 2-3 seconds, refill the reservoir... repeat a few times until clear fluid.
  11. #11
    Feb 2009
    Greenville sc
    45
    992
    Re: Cold Day Blues
    The procedure I saw on here was to jack the car up to unload the front tires, pull one of the cooler lines loose and cycle the steering left to right with the engine off to push as much out of it as you can.
    Mine has 160k and my fluid looks like hammered ass.
  12. #12
    mstrjon32 is offline Cadillac Owners Enthusiast
    Automobile(s): NONE
    Oct 2010
    Mainz, Germany
    788
    Re: Cold Day Blues
    When I bought my V the steering was cutting out on cold days and the pump was whining. I flushed the system with Amsoil power steering fluid (over 3 years ago now, it's due to be changed again) and it hasn't given me any trouble since.
    Quote Originally Posted by ctsv247 View Post
    I did something similar, except I disconnected the return hose, and put it in a large container. Then I had someone start the engine and slowly turn the wheel left to right as I poured new power steering fluid into the reservoir. Did this until there was clear fluid coming out of the return hose. Took less than 20 minutes and the entire system was filled with fresh, clean fluid.
  13. #13
    Feb 2009
    Greenville sc
    45
    992
    Re: Cold Day Blues
    I was able to use the turkey baster method to flush 4 pints of fresh ps fluid through the system over a couple of commutes, stopping here and there to do it while the fluid was warm along the way.
    Although the fluid is still a little darkish, I'm pleased to report that the pump is quiet and seemingly happy at this point.
  14. #14
    WesH8398's Avatar
    WesH8398 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2010
    Sarnia, Ontario, Canada
    35
    897
    Re: Cold Day Blues
    IIRC - the V doesn't hold much PS fluid at all. Seems excessive going through pints and pints of that stuff, but maybe you guys aren't paying the exorbitant prices I had to pay. Think one pint cost me about $35 from the local stealership here. Welcome to Canada. I bought that pint of "cold weather" GM fluid last year and "turkey basted" that through the system. All my cold weather squeal completely stopped and has remained quiet through this winter as well. Including some -20ish startups. Ugh..I always cringe when I turn the key on those mornings. But if Wifey is working that morning too, her '04 Mazda3 gets the garage over my car (she leaves well before I do).
  15. #15
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    Re: Cold Day Blues
    The GM cold weather power steering fluid, (GM Part Number 12345867) which is a synthetic blend, can be ordered online at reasonable prices (e.g. Pace Performance). Incidentally, this fluid is supposed to provide better high-temperature performance as well so it is not a seasonal product. I suspect other good synthetic blends will provide good results (e.g. the Amsoil already mentioned).
  • You may not post replies
