Brake Fluid Change
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V General Discussion Discussion, Brake Fluid Change in Cadillac CTS-V Series Forum - 2004 - 2007; After the last track day (approx 85 miles with speed cycling from 125 to 45 twice in each 1.6 mile ...
    2004ctsv's Avatar
    2004ctsv is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTSV
    Mar 2004
    Blitzburgh
    1,133
    Brake Fluid Change
    After the last track day (approx 85 miles with speed cycling from 125 to 45 twice in each 1.6 mile lap) I decided to change diff, tranny and engine fuids. These swaps are relatively straight forward and well documented in the FAQ site. I figured that I should do the brake fluid also.
    I picked up a quart of ATE Blue Racing fluid (DOT4, $11) and a Motive power bleeder ($60). The system screws on the master cylinder in place of the cap. After a pressure test, I charged to bleeder with one quart of fresh fluid and pumped to 10-12 psi. I attached the drain tube tothe bleeder screw and ran each wheel until the fluid changed from slightly brown tinged amber, then amber, then blue.
    Time required - about 20 minutes including fooling with pump. I couldn't hold pressure until I wet the gasket with a little brake fluid. I didn't have to call my wife or daughter down to pump the brakes and keep refilling the master cylinder.
    Fluid used - about one pint but I probably flushed more blue than I had to.
    Also, I used some cat litter (yes, clean) to soak up the old brake fluid for disposal.
    FWIW
    Tony
  2. #2
    carpe dm's Avatar
    carpe dm is offline Cadillac Owners Member
    Dec 2004
    T
    51
    Re: Brake Fluid Change
    Sounds good. Also sounds like it was time to do a flush. I use ATE in the Vette and have had no problems, although someone told me it might be more prone to attract moisture than OEM stuff.
  3. #3
    ctsvett's Avatar
    ctsvett is offline FAQ is your Friend
    Automobile(s): CTS-V
    Feb 2003
    California
    3,987
    If you want to write up a brake fuild change procedure with pictures, I will put it on the FAQ?
    Reed
  4. #4
    urbanski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,163
    that power bleeder sounds awesome!!!
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
  5. #5
    Dreamin is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 ATS-V
    Feb 2004
    Calif.
    2,261
    Motive power bleeder... good stuff maynard
  6. Remove Advertisements
