Strange Knocking
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V General Discussion Discussion, Strange Knocking in Cadillac CTS-V Series Forum - 2004 - 2007; This has happened twice now in the past four days and I can't put my finger on it. It happens ...
    Tall Cotton is offline Cadillac Owners Member
    Automobile(s): none
    Oct 2012
    53
    4
    Strange Knocking
    This has happened twice now in the past four days and I can't put my finger on it. It happens while doing "stoplight to stoplight" driving. Nothing evil just a usual run through the gears up to 3K each to about 45 mph, stop at light, wait, repeat.
    When stopped at a light in idle, trans in neutral and clutch in I get a Knock...knock...knock... One about every second. It comes from the engine/trans area and I can feel it in the shift lever. The first time I got about four or five before it stopped and then this morning I got about six to eight.
    '04, Everything stock, 88K
    Oil pressure is good, 35-40 psi.
    Motor mounts "should" be good - they were checked two weeks ago by the techs at my local Caddilac dealer BUT I do see a couple of brown streaks on the passenger's side mount. I checked the mounts by engaging the clutch with it in 1st and the parking brake on. I didn't see any engine movement...
    Could it still be the mounts?
    Bearings?
    Sumpin else?
    Thanks.
  2. #2
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,362
    Re: Strange Knocking
    Could still be the mounts. Check under the car by the shifter to see if the shifter or shifter assembly is hitting something. Mine did this and it was a combo of the trans mount and motor mounts being bad.
  3. #3
    Automobile(s): none
    Oct 2012
    53
    4
    Hope it is. I've got the Creative Steel engine and trans mounts ready for install. Going in when the Kooks arrive!
    Thanks!
  4. #4
    odla's Avatar
    Nov 2006
    miami ,Fl
    2,362
    cool report if it does fix the issue.
