New '05 V owner would like some insight ...
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V General Discussion Discussion, New '05 V owner would like some insight ... in Cadillac CTS-V Series Forum - 2004 - 2007; Hi all, As I have noted in a post a few days ago, I have recently purchased a 2005 V. ...
    kck77 is offline Cadillac Owners Member
    Automobile(s): 2012 Corvette Grand Sport Coupe & 2005 CTS-V Platinum
    Nov 2013
    10
    Hi all,
    As I have noted in a post a few days ago, I have recently purchased a 2005 V. As a past and present owner of GM performance vehicles, I know that maintenance is key to a long happy relationship with your car. After spending hours reading through posts and other material, I have noticed ( like with many performance vehicles ) that aftermarket parts are usually the choice of most when it comes to repairing and replacing parts…. this leads me to my question: In regards to the V1, is using aftermarket parts really that much better than oem ( where oem parts are still available) ? The V I purchased has 50,000 miles and no apparent need for immediate attention, but I am going to go through the car and do a full maintenance of all fluids, filters, etc, and replace a bunch heavily wearable parts consisting of diff/carrier/trans bushings, motor mounts etc. I do not track, race or abuse the car…. just a little spirited driving. I get a really good discount at my GM dealer on parts and would prefer to simply head down to the parts department and purchase all the oem fluids that were originally used in the car ( power steering fluid, transmission fluid, diff fluid, limited slip fluid etc) as well as all the original oem bushings, filters, motor mounts etc… .. OR is it worth the time to research aftermarket fluids and parts and track everything down. Any feedback would be appreciated! Thanks
    … I should add the car is completely stock and has never had any thing replaced
  2. #2
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,815
    Re: New '05 V owner would like some insight ...
    Getting an aftermarket shifter and a CAGS eliminator are two that come to mind immediately. Based upon your driving style, I wouldn't do anything else.
  3. #3
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    Going to the dealer and getting all brand new OEM parts would be fine if you don't beat on it. But it's not going to be cheap.
    As an example, I believe that the list price of an OEM transmission mount is $523. Figure an hour for them to R&R and you are looking at close to $650 out the door.
    -Even if your local dealer gave you 50% off you'd still be looking at $260 for a new trans mount.
    -The popular alternative is the RevShift insert, $40+sh and 15 minutes to install.
  4. #4
    alradco's Avatar
    alradco is offline Cadillac Owners Fanatic
    Oct 2011
    43
    484
    It just depends on the part, some like mentioned above makes sense to do aftermarket. For things like fluids, filters, I like to use OEM.
