Reset Airbag System without GM Tool? I've searched, i've searched. Plz Help.
Results 1 to 6 of 6
2004-2007 Cadillac CTS-V General Discussion Discussion, Reset Airbag System without GM Tool? I've searched, i've searched. Plz Help. in Cadillac CTS-V Series Forum - 2004 - 2007; So, as many of you probably don't know, I'm located in Germany with my V, with very little GM assistance ...
    Silencertk is offline Cadillac Owners Member
    Automobile(s): CTS-V V1
    Oct 2012
    Germany
    36
    97
    ExclamationReset Airbag System without GM Tool? I've searched, i've searched. Plz Help.
    So, as many of you probably don't know, I'm located in Germany with my V, with very little GM assistance available. Recently had a minor accident, however enough for the driver airbag to deploy. (It seriously was not a big accident worth deploying a airbag, but oh well.) I repaired the vehicle myself, replaced the airbag, and the front impact sensor located at the top, right behind the hood latch. However, my Airbag light stays on, and - service Airbag is displayed.
    I've removed the airbag fuse underneath the seat, turned the car off, replaced it, turned the car back on - no change.
    There are no dealers close by that can do work on a us spec car. Is there any way I can reset the entire system, or flash blinky whatever to find out what is causing the problem?
    Any help is appreciated.
  2. #2
    cgroh89 is offline Cadillac Owners Member
    Mar 2012
    28
    52
    Don't know gm systems specifically but I do know Ford and when a deployment is necessary generally the module needs to be replaced as well. There is likely an collision event stored in the RCM that you will bot be able to clear with out a tech 2 or new module
  3. #3
    jclayc's Avatar
    jclayc is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Sep 2008
    SC
    43
    418
    Re: Reset Airbag System without GM Tool? I've searched, i've searched. Plz Help.
    I can't guarantee that you don't need modules replaced but I do know the airbag "codes" can be reset using a better-than-average OBD code reader. The hand held (cheap) one I have for P codes doesn't pull them up but I use my PC, a OBD to USB cable and Scan XL from http://www.palmerperformance.com/ and can pull up the restraint system codes and re-set them.
  4. #4
    Oct 2012
    Germany
    36
    97
    ok, maybe i'll look into the whole - odb to usb and scan software thingy.
  5. #5
    jclayc's Avatar
    Sep 2008
    SC
    43
    418
    I believe I have this OBD to USB cable: http://www.amazon.com/ELM327-OBDII-C...sxp_grid_i_0_1. It's $12.
    It may come with free software or you might be able to find free software online that can pull the Passenger Restraint codes but I went ahead and spent the $99 to get the Scan XL program
  6. #6
    Oct 2012
    Germany
    36
    97
    I have a bluetooth odb interface. Maybe I can connect via laptop (normally use my android) and find some software on the net that can access the proper module....
  7. Remove Advertisements
