Vibration after Exploding Diff - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
2004-2007 Cadillac CTS-V General Discussion Discussion, Vibration after Exploding Diff in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by JFensty So I think I have more questions than answers at this point. How much spacing is ...
  1. #16
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    Quote Originally Posted by JFensty View Post
    How much spacing is there between the diff and the CV? I have approx 1/4" - 3/8". If this is good then I guess I tore an axle seal because it is leaking.
    There is no runout whatsoever on the entire driveshaft. There is about an 1/8"-3/16" runout on both axle bars. This is odd since there is no movement at both inner and outer stubs.
    Last but not least, at close to 3k rpm in fourth the resonator starts to bounce (?). You can feel the vibration in the exhaust the most. It is not hitting anywhere on anything. Could this be as simple as a miss?
    That is what I did last night. Above is my findings.
    Things I have confirmed:
    -It is it rpm related not speed.
    -My driveshaft shows no movement throughout.
    -I can feel the vibration through the exhaust and actually watch the resonator "bounce" up and down with the vibration. It is almost better described as a pulsing vibration.
    - The axles may have some movement in the cv's causing the bar to have some runout.
    I'm starting to lean towards engine / exhaust related. Or at the very least trans forward. It may be purely a coincidence. I would think a clogged cat would get worse with higher rpm not a specific range. There is no loss in power.
    Would a small dent in the exhaust cause some weird frequency resonance?? The exhaust does sound louder but its resonating more than before.
  2. #17
    voodoochikin04 is offline Banned
    Automobile(s): 2003 cts, 2004 Cts-v
    Nov 2012
    Norfolk, NE (eastern Nebraska)
    31
    316
    Re: Vibration after Exploding Diff
    Maybe your issue has no correlation with the exploding diff...and is just coincidence. I can't recall.. Stock flywheel?? Also you say its rpm related. Meaning you can reproduce it in neutral in your driveway?
  3. #18
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    LS7 clutch and flywheel almost 50k miles ago, when cam, headers, and tune was done. Its not as bad in neutral, but its there. It mostly shows up under light load to part throttle. At WOT it is roughly equal to being in neutral. When it is at its worst (4th closer to 3k rpm) I can push in the clutch and as soon as rpm drops, the vibe goes away, even if speed remains the same.
    I will be picking up a new axle seal and pulling both axles tonight to re-inspect them. Slowly I am ruling out the diff and all associated with it. This is only causing me more confusion. I may just replace my balancer for piece of mind even though there is no wobble there either.
    Odd thought, my alternator bearing has been making a little bit of whine. Voltage is perfect. I wonder if it sitting for a few days while the diff was being shipped could have caused it to ??something?? making this oscillation travel through the exhaust. I do have UMI mounts so the added nvh from something like this is more likely.
  4. #19
    MarkFJ40 is online now Cadillac Owners Member
    Automobile(s): 05 CTSV
    Oct 2013
    62
    Could it be a low grade miss? Spark plugs or coil?
    Does it do it under load like pulling a hill?
    My truck needed spark plugs and it was missing under load. I thought it was the transmission slipping.
    Never spit any codes either.
  5. #20
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    Interesting. The plugs and wires may be 20k miles old. I was out in the dark looking for any arcing of the wires. Not getting any kind of codes at all.
    I guess next will be to clean my Maf and filter, and inspect plugs and wires as well....
  6. #21
    Nov 2012
    31
    316
    jfensty... check your pm's
  7. #22
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    Quote Originally Posted by voodoochikin04 View Post
    reply sent.
  8. #23
    Oct 2013
    62
    Check the porcelain for cracks. I was troubleshooting a miss forever and it turned out one of my new plugs was cracked
  9. #24
    robojesus is offline Banned
    Automobile(s): of
    Aug 2012
    gay
    184
    ha, my driveshaft isn't indexed anymore. I had it apart when I did my cradle bushings, and unfortunately it wore clean off of the connections.
  10. #25
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    Quote Originally Posted by robojesus View Post
    Did you notice any difference?
  11. #26
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    I have a rubber coupler I'd sell if you need it. Just PM me.
  12. #27
    JDB's Avatar
    JDB
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    Apr 2010
    PA
    1,070
    Damn... too many launches at the drags chasing Vettes at the County Corvette charity events?
    I was going to do it last time, bit this just reinforces to be a spectator again.
  13. #28
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    Quote Originally Posted by JDB View Post
    Nope, once I get this vibration deal figured out, I will be in the next charity event shooting for mid 12's.
  14. #29
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    Odd update... I began this morning pulling one piece at a time and then running it up in forth to 2800 or so to see of the vibe had diminished at all. After pulling both axles the vibe was still there. The axles both have some play in the hub end. And the hubs have a tiny bit of bearing noise. Replacements on the way, but I do not believe they are causing my issues.
    Dropped the exhaust and started it up, big smile, and run it up to about 45 or so and no vibes. Now I am going to run this test again, mostly due to the fact that the car shakes from the sound of open header and it may be disguising the original vibe.
    My exhaust is muffler delete and high flow cats. Could the resonator be coming apart and causing some resonation or oscillation that is being transmitted as a vibration? I guess that would make sense that it is usually only between 2-3k rpm and under load.
    Next is to drop the driveshaft and diff, then reinstall exhaust and check again to rule out exhaust totally.
    Thoughts?
  15. #30
    Nov 2012
    31
    316
    Yea...one thought.... Thats a lot of work!!!!! Lol
  16. Remove Advertisements
