Service Stability System issue.
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V General Discussion Discussion, Service Stability System issue. in Cadillac CTS-V Series Forum - 2004 - 2007; I've been looking for info everywhere on google and haven't found much luck. I have an 04 CTS-V completely stock ...
    ninnyCTSV is offline Cadillac Owners Member
    Automobile(s): 04 CTS-V
    Jun 2013
    Moreno Valley, CA
    29
    4
    I've been looking for info everywhere on google and haven't found much luck. I have an 04 CTS-V completely stock other than a cags delete. Lately I've been having an issue with the Service Stability System message coming on, but it's causing the driverside front brake to engage. So much that it causes the car to swerve. I've checked for any noticeable issues but have yet to find anything. Sometimes it shows the message the second I turn the car on and other times while i'm driving, and sometimes even not at all. I'm hoping someone might be able to point me in the right direction so I can get this taken care of
  2. #2
    voodoochikin04 is offline Banned
    Automobile(s): 2003 cts, 2004 Cts-v
    Nov 2012
    Norfolk, NE (eastern Nebraska)
    31
    316
    Re: Service Stability System issue.
    I had a similiar issue, where it would say service stability system right when id start the car. Sometimes it would say it when I had steering wheel turned all the way one direction while backing out of a parking space.. check all the wired clips at each wheel... for any breaks or bare wires. Then unplugg and reconnect all the plugs for all 4 wheels. doing that, fixed my problem. Also might want to have all the codes cleared, and then disconnect/reconnect the plugs.
  3. #3
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,365
    Do a search on this forum and you should find your answer. It has been gone over a lot here. There are a few possible causes.
  4. #4
    stever06 is offline Cadillac Owners Member
    Automobile(s): 2004 cts-v
    Apr 2013
    schaumburg IL
    47
    39
    yes do the search, I had the same problem as you I had to replace my swps steering wheel positioning sensor. the sensor is on the steering column after I replaced mine (there is a write up for this) it has not gone on sense.
