Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Can I change the idler pulley?
    aantalis's Avatar
    aantalis is offline Cadillac Owners Member
    Automobile(s): 2005 CTS V Stealth Grey 2008 Hot Lava
    Dec 2007
    Indiana
    41
    Dealer just quoted $275 to change the idler pulley and serp belt. I have a loud whine consistent with that diagnosis. I have changed these on other cars. Are there two pulleys? Should I also change the tensioner? Anything to worry about on my LS2 ? Are there 2 pulleys? Anything special tools needed? I have the usual belt changing setup tools. Thanks for any advice.
  2. #2
    PISNUOFF Guest
    re: Can I change the idler pulley?
    There is one idle pulley attached to the alternator bracket and a tensioner pully idler. Either can be swapped with just a 15mm socket.
  3. #3
    69stangscj's Avatar
    69stangscj is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V sedan, 69 Mustang Mach I
    Jul 2013
    Dayton Ohio
    331
    I've pressed new bearings in the idler pulley's before also. Worked great, most use the same bearing.
  4. #4
    aantalis's Avatar
    Dec 2007
    Indiana
    41
    Thanks, I think I will change both and get a new blue gates belt. Should I trust the dealer diagnosis or while i'm at it change the AC pulley and belt also? I don't plan on removing the radiator. 78K mi .Thanks for your advice.
  5. #5
    PISNUOFF Guest
    The a/c pulley will be a lot more work. Unless you mean the a/c tensioner pulley.
    Did the dealership not investigate what pulley is making noise and just recommend changing all of them? This I why I hate dealerships and the hacks they hire to work on people's cars.
  6. #6
    aantalis's Avatar
    Dec 2007
    Indiana
    41
    They said the "idler Pulley" but I don't trust them. Thought I might do some preventative maintenance and change the ac tensioner pulley and belt if its not too hard. Probably just do the Serp belt and pulleys and see if that fixes the problem. Its a constant loud whine, not a chirp. Thanks for your advice.
  7. #7
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Hey aantalis,
    Try changing the easiest one first (idler pulley) and see if the whine goes away. I will say my Jeep alternator was making a high pitch whine before I replaced it. It was still giving out the correct voltage, it was just a bad bearing.
    I can always help ya if you need it.
    Also, if you have a 2005, you have an LS6.
  8. #8
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,372
    So what ended up fixing the whine? I have the same symptoms. I think my alternator is going out.
  9. #9
    vavavavance is offline Cadillac Owners Member
    Automobile(s): Black 2005 cts-v
    Jul 2011
    50
    14
    Re: Can I change the idler pulley?
    I think I"m in need of a new tensioner pulley....can I change just the pulley or do I need to change the tensioner set up as well? Any Part # available for pulley? Thanks in advance
  10. #10
    Mar 2012
    Rochester Hills, MI
    237
    Usually the tensioner pulley goes first. Its fairly straight forward. If you can get in there put a long extension on the bearing in question (when I say long I mean like a 2 footer) while the engine is running. You will be able to feel the bad bearing.
  11. #11
    Jul 2011
    50
    14
    Excuse my ignorance... I'm pretty sure the bearing is gone as there is now a loud whine coming from the area. It's the tensioner pulley near the top left of the engine. Can I change "just" the pulley, as opposed to changing the "tensioner arm and pulley"?
  12. #12
    rand49er's Avatar
    rand49er is online now All V1s should be maggied.
    Jan 2005
    South Lyon, MI
    68
    13,831
    For $75, here's a used one on eBay. Is it the correct one?
    http://www.ebay.com/itm/04-05-CADILL...5755f5&vxp=mtr
  13. #13
    Jul 2011
    50
    14
    Thanks for the help guys...picking up new pulley tomorrow...gonna start with that. On a side note...would the arm have anything to do with the whine? Some fellow told me that "might" be the problem as well...I just don"t understand how that would cause a whine.
  14. #14
    69stangscj's Avatar
    Jul 2013
    Dayton Ohio
    331
    I doubt it causes the whine, but if the lever bounces alot the spring in the lever could be wore too.
  15. #15
    Jul 2011
    50
    14
    I'm thinking I'm ok on that note...from observation it barely moves
    Is there a torque spec for the pulley bolt?
    Is there a need for loctite?
  • You may not post replies
