Rear wheel facing the wrong way
Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Like Tree8Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Rear wheel facing the wrong way in Cadillac CTS-V Series Forum - 2004 - 2007; Long story short - while leaving work a kid ran into the street and I swerved to avoid him. Hit ...
    darien99's Avatar
    darien99 is offline Cadillac Owners Fanatic
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    33
    194
    Long story short - while leaving work a kid ran into the street and I swerved to avoid him. Hit the curb with my RR wheel after doing a 180, and here's the result. I couldn't have been doing more than 20 at the time so I'm sort of surprised there's so much damage - but I suppose the vehicle wasn't meant to be driven into curbs.
    So I guess my question for those of you more familiar with the vehicle is - what am I looking at? I'm thinking (hoping?): replace the control arm and hope for the best? Anything else I'm missing? I should add that I'm new to RWD so the components aren't intimately familiar to me. Any help would be appreciated.
  2. #2
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Re: Rear wheel facing the wrong way
    You bent your toe rod into an "S" curve. I can see it clearly in the last picture. Look straight up from the caliper. You'll need to replace it and get an alignment. Here's a picture of what the toe rod should look like:
    Here's a partial picture of the OEM toe rod on the left side of my car (right side of the picture):
    And here's one of my BMR toe rods (the red rod to the left of the hub):
  3. #3
    darien99's Avatar
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    33
    194
    Right on, so it's a dealer only part, correct? Replace it and cross my fingers, you think? I was worried about the upper and lower control arms - I know aluminum doesn't generally bend but those wishbones are a funny shape and I couldn't tell if mine was bent.
    Anyone have a part no. for the toe rod?
  4. #4
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,833
    Call Luke at Lindsay. Might have to wait till Monday, though.
  5. #5
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,537
    It's hard to tell what might be bent based on blurry cellphone pics. (What happened to the days when people took pictures with digital cameras so that pictures were actually clear?) I would be concerned the trailing arm is bent, as it clearly took some impact from the wheel (4th pic). And I'm also curious if the "ears" on the stamped steel lower control arm are bent as a result of the knuckle being twisted that much - I don't know if there's enough flex in the bushings to allow the knuckle to have that much toe in without something bending. The wheel bearing/hub assembly may be toast from the load that was applied to it.
    Some unsolicited advice... I'm not trying to be a dick here, but if you lost control of the car due to a single evasive maneuver at not even 20mph, you need to work on your driving. Get to an auto-cross event and figure out how the car handles at the limit. Presumably, you didn't hit the kid, which is good, but the fact that you lost control of the vehicle in such an innocuous situation is bad. In a different situation, you may have missed the kid, only to spin into an oncoming car, or to spin and hit the other kid who crossed the street ahead of his friend.
    Pillow, Dan_Gurney and FuzzyLogic like this.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  6. #6
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    I have the rear upper control arm and trailing arm if needed
  7. #7
    Mar 2011
    2,045
    AAIIIC, good call on the wheel bearings. They could easily be trashed. If I were the guy, I'd disengage the parking brake, spin the rotor by hand, and see if I could work the hub at angles. Listen for abnormal sounds, excessive play, and binding.
  8. #8
    darien99's Avatar
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    33
    194
    AAIIIC - I appreciate the mechanical advice. To clarify: I hit the curb at around 20. I was probably doing about 35 at the time of the maneuver. I do think that you're right that the best outcome was avoiding the child, but I can't agree with your autocross suggestion. It was a panic situation where a kid darted across the street, I wasn't trying to drive my car at the limit. I understand the concept of muscle memory from riding streetbikes, but this was a case where given the distance and time I had to act I feel I did the best thing (even if it does mean I have to shell out some money for repairs).
    I did use a digital camera (Canon SX210 is) but I was in a hurry to get pictures before it got dark and didn't get everything focused, I was supposed to meet someone for a date tonight. I can get clearer pictures if needed. What you see on the trailing arm is where the tire rubbed the paint off as I drove a short distance.
  9. #9
    Mar 2011
    2,045
    I would check eBay for toe rods, if you can do without your car for several weeks, or consider this an opportunity to pick up a set of Creative Steel or BMR toe rods. Presently, a quick check of eBay indicates that there are no used toe rods available. But they pop up now and again.
  10. #10
    jerkyboy is offline Cadillac Owners Member
    Sep 2013
    Upstate NY
    55
    Quote Originally Posted by AAIIIC View Post
    Ouch!!!!!
  11. #11
    eagle-co94's Avatar
    eagle-co94 is offline Cadillac Owners Fanatic
    Automobile(s): '09 V, '10 SRT8 Chlnger, '96 Impala SS, '85 Mini, '11 9C3
    Jul 2013
    Hollywood, FL
    151
    Darien, I'm currently parting out an '05 and have the complete rear suspension and subframe available. PM me exactly what you need as my prices are more than fair.
  12. #12
    darien99's Avatar
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    33
    194
    Damn eagle, I wish I had seen this before right now. I just bought the toe rod from the local dealer to the tune of $150. Definitely get it used if you can if you're ever in my situation. I'm going to try to replace it after work tomorrow night and hope that solves my issue, but if not I'll be in contact.
  13. #13
    eagle-co94's Avatar
    Jul 2013
    Hollywood, FL
    151
    Not a problem. It if turns out "it wasn't what you needed" and you take the part back I would only have asked like $35 shipped. I just got access to the forum tonight after 6 weeks of being locked out, otherwise I probably would have seen it sooner.
  14. #14
    Junior1's Avatar
    Jun 2008
    1,248
    Bring it back at that price...
  15. #15
    darien99's Avatar
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    33
    194
    Junior - get in touch with me and I'll see if i can take it back.
  16. Remove Advertisements
