| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Getting PCM Tune...what changes would you recommended?
04-28-05, 06:24 PM
|  | Cadillac Owners Member | | Join Date: Feb 2005 Location: Charlotte | | Getting PCM Tune...what changes would you recommended? I am getting the MorePerformance Corsa/Cold Air package with a PCM tune and want to get some recommendations on things I should ask MP to change while they are programming. I am sure they will have their own suggestions...but I would like to hear from the group. (FYI - I will post dyno chart with before/after runs).
So lets here them...
1.) eliminate CAGS
2.) raise rev limiter to? 6500? 6700? ____?
3.) raise top speed to? (I see there is a thread just on this)
4.) can DRL's be turned off in PCM?
5.) what else???
Thanks
Scott (V in CLT) (CLT=Charlotte airport code)
2005 Platinum V |
04-28-05, 06:29 PM
| | my name is Tiffany Cadillac(s): 05 CTS-V | | Join Date: Mar 2003 Location: San 'tone, TX | | | Re: Getting PCM Tune...what changes would you recommended? be careful raising rev limiter if you retain the stock valves/springs.
DRLs cannot be turned off, they have another controller.
Search for threads about DTE for their various stage tunes, for ideas.
Remember, your '05 must be tuned with LS2-Edit, or EFI-Live, not LS1-Edit, and some places don't have the new version in yet  MP should, though. |
04-28-05, 06:37 PM
| | Cadillac Owners Member | | | | | Re: Getting PCM Tune...what changes would you recommended? Quote: |
Originally Posted by VinCLT I am getting the MorePerformance Corsa/Cold Air package with a PCM tune and want to get some recommendations on things I should ask MP to change while they are programming. I am sure they will have their own suggestions...but I would like to hear from the group. (FYI - I will post dyno chart with before/after runs).
1.) eliminate CAGS
5.) what else???
Thanks
2005 Platinum V | I'm new to the GM tuning so bear with me. Do you get a hand held programer to install the tune that you get from these guys. I'd like to do the same Corsa/cold air mod and might even wanna try a small shot of nitrous but I'm not sure how to go about a tune for either or both. Can anyone help educate me. |
04-28-05, 07:16 PM
| | Cadillac Owners Connoisseur | | Join Date: Jan 2004 Location: Connecticut | | | Re: Getting PCM Tune...what changes would you recommended? HP drops after 6100 rpms, no reason at all to raise the limiter, and no reason to even go to 6500rpms, it will just slow you down. |
04-28-05, 07:22 PM
|  | Cadillac Owners Member | | Join Date: Feb 2005 Location: Charlotte | | | Re: Getting PCM Tune...what changes would you recommended? Dr Mustang,
I am aware of basically 4 options for PCM tune...
1.) Handheld Tuner (superchips, predator, etc.) - lets you switch between OEM program and the modified program in the unit - $400
2.) Mail order PCM TUne (DTE, etc.) - send them the PCM and they will reprogram with their DYNO tested tune for your mods. - $300 (No Handheld...PCM must go back to tuner to get changes)
3.) Laptop Software Tune (EFI-Live, LS2-edit, HPTune) you can change all the PCM parameters from your own laptop - $735 to $1000?
4.) Professional Custom Tune (DTE, MorePerformance) - $500 Done to your car on the dyno to dial in your specific vehicle. (No Handheld...car must go back to tuner to get changes)
...following urbanski's advice to...I have searched on DTE....I see
- CAGS deleted electronically
- Quicker wide open throttle activation (How?...via TPS adjustment?)
- Reduced engine operating temperature range from O.E. Now 195*-205* (O.E. 215*-233*) How?...is thermostat programable?
- No A/C drag when WOT is selected and A/C is on (via A/C cut out at __RPMS?)
- No speed limiter |
04-28-05, 07:37 PM
|  | Cadillac Owners Connoisseur Cadillac(s): Twin-Turbo Bimmer/C6Z06 Hunting... | | Join Date: May 2004 Location: MN>ND>MN>SD>IL>MN>IL Age: 41 | | | Re: Getting PCM Tune...what changes would you recommended? Quote: |
Originally Posted by GNSCOTT HP drops after 6100 rpms, no reason at all to raise the limiter, and no reason to even go to 6500rpms, it will just slow you down. | Since I'm not a drag racer, teach me -
Shifting at 6100 rpm, engagement of the next gear is 4200 rpm and ~240 RWHP.
Shifting at 6500 rpm, engagement of the next gear is 4600 rpm and ~280 RWHP.
Shifting at 6800 rpms, engagement of the next gear is 4900 rpm and ~300 RWHP.
Isn't the most desireable strategy to equally straddle the peak of the horsepower curve? If so, 6800 is the sweet spot. |
04-28-05, 07:50 PM
|  | Cadillac Owners Fanatic | | | | | Re: Getting PCM Tune...what changes would you recommended? with tuning, can max hp be changed from 6000 rpm to a higher rpm? Or would I need something else? |
04-28-05, 09:03 PM
| | Cadillac Owners Connoisseur | | Join Date: Jan 2004 Location: Connecticut | | | Re: Getting PCM Tune...what changes would you recommended? Stealth, do the same equation using torque curves instead of HP. |
04-28-05, 09:19 PM
| | Cadillac Owners Enthusiast Cadillac(s): 04 cts v | | Join Date: Sep 2004 Location: Baton Rouge Age: 42 | | | Re: Getting PCM Tune...what changes would you recommended? If you do nothing else get the torque management turned all the way up! |
04-28-05, 10:34 PM
|  | Cadillac Owners Connoisseur Cadillac(s): Twin-Turbo Bimmer/C6Z06 Hunting... | | Join Date: May 2004 Location: MN>ND>MN>SD>IL>MN>IL Age: 41 | | | Re: Getting PCM Tune...what changes would you recommended? Since this was nagging the crap out of the engineer in me, I calculated the V's acceleration force and resultant optimal shift points using the torque curve from my car.
As an experiement - send me your PCM; I'll bump the rev limiter up to 7200. Shift at the calculated rpms next time you're at the track and show us the time slip. Acceleration Force
Reason: Changed file to a link for *smaller* screens than mine. =)
04-28-05, 11:01 PM
|  | Cadillac Owners Fanatic | | | | | Re: Getting PCM Tune...what changes would you recommended? wow... 7200 rpms? What would one have to do to get to 8000 rpms?.. and make the engine produce the power near 8000 rpm? |
04-28-05, 11:53 PM
|  | Cadillac Owners Enthusiast | | Join Date: Feb 2005 Location: Maine Age: 43 | | | Re: Getting PCM Tune...what changes would you recommended? 7200!!!! I wouldn't want to be those Valve springs after a few of those revs....  But hell, if someone wants to try it I would love to see the results..
Bill-05-V   05 CTS-V--- Light Platinum
Llumar Clear Bra and Tinted windows, LS6 Emblem, Stealth-V z06 fuel rail covers and Cags Eliminator,
K&N drop in filter, B&B 3" resonator exhaust....more mods coming..
Online Photos http://photobucket.com/albums/v466/HDMLNIUM/ |
04-29-05, 12:44 AM
|  | Cadillac Owners Master | | Join Date: Mar 2004 Location: Reno, NV | | | Re: Getting PCM Tune...what changes would you recommended? Stealthman knows what he speaks. This isn't rocket science, but I did sleep at a Holiday Inn Express last night. Trust me. Send off yoru PCM.
Wild  out |
04-29-05, 12:55 AM
|  | Cadillac Owners Connoisseur Cadillac(s): Twin-Turbo Bimmer/C6Z06 Hunting... | | Join Date: May 2004 Location: MN>ND>MN>SD>IL>MN>IL Age: 41 | | | Re: Getting PCM Tune...what changes would you recommended? One can easily spin a LS6 well past 7200 rpm.
Valve spring longevity? Well...that is a down side.  |
04-29-05, 02:34 AM
|  | Cadillac Owners Fanatic | | | | | Re: Getting PCM Tune...what changes would you recommended? Unless Stealth slept in the same bed as you last night I dont know how that hotel has to do with stealth.. lol
j/k Quote: |
Originally Posted by wildwhl Stealthman knows what he speaks. This isn't rocket science, but I did sleep at a Holiday Inn Express last night. Trust me. Send off yoru PCM.
Wild  out |
| | Cadillac Discussion Tools | | |
Censor is OFF | | | |
