stability control activates at high engine rpm.
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By RyRidesMotoX
2004-2007 Cadillac CTS-V General Discussion Discussion, stability control activates at high engine rpm. in Cadillac CTS-V Series Forum - 2004 - 2007; OK, here is the symptom. You are driving down the road and decide to run a year out to the ...
    throttljock is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Aug 2012
    Ann Arbor
    24
    OK, here is the symptom. You are driving down the road and decide to run a year out to the red line. In third gear, you are near 90 mph and out of nowhere your car flashes "stability control active". A split second later it grabs a brake on you. This is unnerving. Any ideas? Pulling codes didn't point at the SWPS. It gave me C0196. which is a yaw sensor. Of course, I can't find anyone else that has had this issue. The local dealerships tell me that their sales history says they have NEVER sold a yaw sensor, which makes me wonder why me.... remember, this only happens at high RPM (over 4000) Tell me what you know. Thanks guys
  2. #2
    Wingsfan4life's Avatar
    Wingsfan4life is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V Black Raven
    Aug 2011
    Brooklyn Center, Mn
    46
    232
    That's weird IMO...I rev limit mine in 2nd, 3rd, all the time and never experienced this at all...is your break fluid low by chance?
  3. #3
    Aug 2012
    Ann Arbor
    24
    Re: stability control activates at high engine rpm.
    Quote Originally Posted by Wingsfan4life View Post
    Master is full
  4. #4
    jeffctsvmanw is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Aug 2009
    pittsburgh
    60
    17
    Do you hear any noise in audio system? Like alternator whine? Electrical noise might trigger sensor.
  5. #5
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,365
    Um this has happen before. I think it was here on this forum that someone posted the same thing. IF i remember right the sensor is located in the center console. Same thing happened to that car. Same symptoms.
    Edit here is the link that may help you out.
    http://www.cadillacforums.com/forums...car-still.html
  6. #6
    yframe65 is offline Cadillac Owners Member
    Automobile(s): 2004 cts-V
    Jul 2011
    34
    4
    Quote Originally Posted by odla
    Um this has happen before. I think it was here on this forum that someone posted the same thing. IF i remember right the sensor is located in the center console. Same thing happened to that car. Same symptoms. Edit here is the link that may help you out. http://www.cadillacforums.com/forums...car-still.html
    I had a wheel bearing that was going bad and sending bad signals to the wheel speed sensor. It didn't throw any codes and I replaced the yaw sensor first, but it turned out to be that wheel speed sensor.
  7. #7
    Aug 2012
    Ann Arbor
    24
    day one at the dealership = " uh - i don't know"
    thanks - I already had that answer...
  8. #8
    Heavybody is offline Cadillac Owners Fanatic
    Automobile(s): 04 CTS-V and 94 SLS
    Oct 2005
    NH
    149
    Check your G meter ... Guys who had yaw sensor problems reported high readings on the G meter readout... Higher than you have from even spirited driving like 1.9 g's or something crazy. Hopefully my vague memories help some
    I think I remember heavy metals having this problem...
  9. #9
    04cts v is offline Cadillac Owners Member
    Jan 2013
    41
    Do you still have your original 2-piece driveshaft installed? Any noises/whining from under the car after hard acceleration? I had similar problem and replaced my driveshaft with a one-piece...problem fixed. Bushings in carrier were getting worn and created false traction control issues.
  10. #10
    Aug 2012
    Ann Arbor
    24
    At the very least, this seems like good justification for a nice upgrade.
  11. #11
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    Quote Originally Posted by Heavybody View Post
    If that's the case... Before you reset everything... Take a picture so you can tell everyone how much more badass the V is than everything else.
    Hammar likes this.
  12. #12
    Uselesryder919 is offline Cadillac Owners Member
    Automobile(s): 04 CTS-V Raven
    Sep 2013
    29
    26
    i just think i solved this issue with my car. i cleaned the hubs the best could but what i belive fixed the issue was i disconnected the battery for 10 mins and pulled the TCS and SCS fuses attemting to reset the system. my car hasnt tried to kill me in 4 days lol.
  13. Remove Advertisements
