04 Oil pump R&R in car??
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By pato
2004-2007 Cadillac CTS-V General Discussion Discussion, 04 Oil pump R&R in car?? in Cadillac CTS-V Series Forum - 2004 - 2007; So my wife's 04 with 222K miles has 0 psi oil pressure and I've scoured the net to see if ...
    chet is offline Cadillac Owners Member
    Automobile(s): 2004 ctsv Black, 2013 CTS Performance Diamond Black
    May 2004
    NorCal
    48
    55
    So my wife's 04 with 222K miles has 0 psi oil pressure and I've scoured the net to see if the oil pump can be replaced in the car. Looks like a real bitch if it's even doable at all. I see that other vehicles with LS engines, like the late model Cameros can change the pump without pulling the engine.
    Trying to squeeze a few more miles out of this practically untouched(new waterpump) LS6. Cheers, Chet
  2. #2
    Becker's Avatar
    Becker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 black with tan V
    May 2013
    31
    391
    Re: 04 Oil pump R&R in car??
    i dont see why you would not be able to. Pull the fans, rad, move the condensor, pull the pump and timing cover and work at it right there. I changed ls1 oil pump no problem in the car
  3. #3
    jmargo is offline Cadillac Owners Fanatic
    Automobile(s): 04 V
    Dec 2011
    Nor Cal
    169
    Have you verified the oil pressure switch. The pump does not normally just fail to zero.
  4. #4
    May 2004
    NorCal
    48
    55
    I put a new oil pressure switch just to be sure, and the car still screams at me: Shut if off now!! Engine runs but making lots of noise now that it's sat for about a month. Hoping a fellow V owner or a Tech that's done this procedure can chime in. My concern is getting the oil pan down far enough to get at the oil inlet tube connector bolt. Seems like the front torsion bar and Brake portioning valve (Not sure what it's called) are right in the way. Thanks for the feedback.
  5. #5
    pato is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V
    Aug 2011
    186
    I replaced my oil pump with the engine in car in my 2005 V. Just like with any other LS engine. Oil pan goes down far enough to get to the pickup tube bolt, at least for me it did. Nothing that you mention was in my way.
    Becker likes this.
  6. #6
    May 2004
    NorCal
    48
    55
    Quote Originally Posted by pato View Post
    Excellent! Now I just have to pray that something else didn't cause the oil pump failure, did your pump fail on it's own?
  7. #7
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
  8. #8
    Aug 2011
    186
    Quote Originally Posted by chet View Post
    No, old oil pump had good pressure, I just replaced it because I put in a new crank balancer, which since I was there led to a new front seal, since I was there led to a new oil pump, a oh what the hell, lets put a new timing chain on too, which also led to new valve springs.
    Engine had 108k miles at that point, so I just did all that for peace of mind, since I was there, lol.
  9. #9
    May 2004
    NorCal
    48
    55
    Thanks for the link, that's a great step by step how to.
  10. Remove Advertisements
