Results 1 to 2 of 2
Thread: Service Stability System
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    I rec'd a service stability system notice on the DIC in which the traction control and abs lights illuminated on the dash. I figure it is a wheel sensor and plan to replace both front hubs. The notice only comes up twice over the last week. Today I get the notice and dismiss it as I do not get any negative effects. Then the service vehicle soon notice pops up and then battery not charging notice. DIC shows 13.6-13.8 Voltage while driving. Car starts perfectly. Negative cable was a little loose and i cleaned both cables and tightened. No check engine light is illuminated, and nothing is showing up on my Bluetooth obd II scanner with torque app. Any thoughts? I can't get the car to a mechanic with a good computer until Friday. Should I be worried? Anyone with the same issues? 04 V with 152k.
    I don't think it matters, but I have one tpms not reading that is also getting replaced on Friday
  2. #2
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,463
    Re: Service Stability System
    My guess is the two issues were unrelated. I've had both of those indications on separate occasions - alternator died and gave me the "Battery Not Charging" and "Service Vehicle Soon" warnings last year. A month or two ago a wheel sensor died and gave me the "Service Stability System" warning and TC and ABS lights on.
    I would recommend getting the code pulled to figure out which hub it is rather than just replacing the fronts. It could be one of the rears, too.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  • You may not post replies
