Clutch Master Cylinder - ? before installing
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V General Discussion Discussion, Clutch Master Cylinder - ? before installing in Cadillac CTS-V Series Forum - 2004 - 2007; I've had a few grinds going into 4th at high RPM's with the new transmission. I've got a feeling it ...
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    I've had a few grinds going into 4th at high RPM's with the new transmission. I've got a feeling it had to do with needing bled and heat. Since it has cooled down outside I have had a few successful 4th gear shifts.
    Among all of this, I had been doing a lot of reading and came across guys with f-body camaros talking about a drill mod to the master cylinder to open up a restriction in the master to slave line. Their symptoms matched my problem exactly; grinding into 3/4 on high RPM's.
    I bought a GM master cylinder to investigate myself: There are NO restrictions in the hoses on our master cyliinder.
    There is one small port to the hose that goes to the reservoir, is that any sort of restriction point ?
    I was going to install this new MC and put a piece of heat sheild over the entire hose; but now that I see i can disconnect the MC from the Slave easily I might just slide the heat shield over the existing line and see how that goes before attempting to tear into this.
    Only reason I have been looking into the MC was because it is the only part that has not been replaced in the clutch system.
    Any suggestions or comments before I do anything ? Thanks again.
  2. #2
    Aug 2005
    Northern IN
    1,006
    Re: Clutch Master Cylinder - ? before installing
    This was one of the articles I found a while back:
    http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/124634-drill-mod-slave-ewill3rd.html
    While I'm here, any tips on how to get the clip back on the quick connect fitting. This thing is a PIA; push the hose in the fitting and then I can not get the clip to snap on around the hose to hold it in. At least its a spare part right now, but would still like to get it back together.
  3. #3
    jamesdem1123 is offline Awaiting Email Confirmation
    Automobile(s): 2006 CTS V
    Nov 2012
    29
    20
    The thread is a couple months old, but what size/type of threading is on the master cylinder that goes to the feed line to to the slave? It looks proprietary, are there any screw on connectors? I'm working on a replacement with a tilton unit without having to to hack up a $200 adapter and your firewall.
    Currently my car is in Fl, I am in NY.
    Thanks
  4. #4
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by jamesdem1123 View Post
    Thanks
    I believe the threading for the clutch line is proprietary because a few years ago UUC in partnership with Lindsay Cadillac investigated the design of a stainless steel clutch line to be included with their brake line kit for the CTS-V. Although they did produce and sell the brake lines, they (UUC/Lindsay) reported that they could not do the clutch line because the connectors were proprietary.
