Coolant Temp INOP (Sensor changed) ;/
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V General Discussion Discussion, Coolant Temp INOP (Sensor changed) ;/ in Cadillac CTS-V Series Forum - 2004 - 2007; Hey guys this morning I got the engine hot turn AC off and then looked and had no coolant temp ...
    Becker's Avatar
    Becker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 black with tan V
    May 2013
    31
    391
    Hey guys this morning I got the engine hot turn AC off and then looked and had no coolant temp readings After work I changed the sensor and cleaned up and pulled the car back in and noticed NO CHANGE. I do have a SES light and I own a scanner but its late and I have to be up at 0400 manana.
    1. Does the car need time to reset it?
    2. Can I speed up this reset time, if it in fact needs to be reset?
    3. What else could it be, a short? (hopefully not)
    4. What would be the typical code associated with this (I will be scanning tomorrow)
    5. .....is it safe to drive? I assume so but it does drive a bit different - kind of like a cold startup
    6. Help please
    Thanks,
    Becker
  2. #2
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,372
    Re: Coolant Temp INOP (Sensor changed) ;/
    Try disconnecting the battery for ten min.
  3. #3
    Becker's Avatar
    May 2013
    31
    391
    Thanks,
  4. #4
    robojesus is offline Banned
    Automobile(s): of
    Aug 2012
    gay
    184
    so you'll make a thread online rather than using the scan tool you already own to try and clear the code?
    It's driving like a cold startup probably because it's pulling all the timing.
  5. #5
    Becker's Avatar
    May 2013
    31
    391
    Yes made a thread online to ask if it would take time for the car to see the new sensor. Not/Wasnt worried of the code but when I changed the sensor after work and cleaned up the car sat and idled for 20 minutes and still registered no coolant temp. I never even scanned the code because it cleared on my way home the next day.
    My thread was merely asking if it needs time to reset - which it did after 100 miles or so.
    Yes, it did drive like it was in open loop but I was just puttin' around town in it and not ripping on it - for obvious reasons.
  6. Remove Advertisements
