Is there a specific V part number for power steering pum?p
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V General Discussion Discussion, Is there a specific V part number for power steering pum?p in Cadillac CTS-V Series Forum - 2004 - 2007; Something blew in my power steering system and fluid starting leaking. (133K) I can't determine source yet but will in ...
    Motown Cad is offline Cadillac Owners Fanatic
    Automobile(s): 07 Silver V Sport Susp.
    Jun 2011
    Southern MD
    51
    147
    Something blew in my power steering system and fluid starting leaking. (133K) I can't determine source yet but will in a couple of hours on lift. I'm assuming I need a new power steering pump as it was groaning very loud as I lost assist in steering. But it could be hoses as well. God forbid a rack and pinion unit. Autozone was pretty useless as their system says pump not manufactured anymore.'
    Is there a specific V p/n for pump, hoses and rack n pinion unit? Any help is appreciated as I have a big job coming up.
  2. #2
    Jun 2011
    Southern MD
    51
    147
    Re: Is there a specific V part number for power steering pum?p
    No ideas on part numbers? Autozone and napa say it's not made anymore. Anyways, I found the culprit. Galvanic corrosion on the high pressure hose fitting going into bottom of Steering Pump Assy. I'm assuming that's where the seal is and it's probably beat to crap from corrosion. So I'll replace pump and hose set. The aluminum on aluminum fittings on the rack and pinion are good to go and it's not leaking there so I think I'm good to go. The reason I'm asking about P/N's is alot of sights don't differentiate between CTS and V's. If the pumps and hoses are the same between the two, than cool. Otherwise, I'll need to research and call. I'm glad I waited to put my set of gatorback belts on. Side note: I'm thinking of moving the power steering pump cooler up or down into the grill openings and rotating it 90 degrees since it's sitting EXACTLY BEHIND THE FRONT BUMPER. Thoughts? Advice? Thanks.
  3. #3
    Jun 2011
    Southern MD
    51
    147
    Found website that distinguishes V and 6.0L parts from 3.8 etc. 61 views w no replies, looks like I should provide for a change. Here is website and they have GM parts diagram too so I like it. I got pump, HP hose and pulley for $299 shipped.
    https://www.gmpartsclub.com/index.php?p=home
  4. #4
    NCOGNITO's Avatar
    NCOGNITO is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V - Black Raven
    Apr 2012
    39
    283
    For future reference ... Nalley GMC has their parts listings online here - http://parts.nalleygmc.com/productSe...wer%20steering
  5. #5
    Jun 2011
    Southern MD
    51
    147
    Even better diagrams and closer to Maryland, thanks!
  6. Remove Advertisements
