New Trans + Monster Stage 2 Clutch w/ 28# Flywheel - Slight Grind into 3rd & 4th.
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V General Discussion Discussion, New Trans + Monster Stage 2 Clutch w/ 28# Flywheel - Slight Grind into 3rd & 4th. in Cadillac CTS-V Series Forum - 2004 - 2007; So I have finally put 500 miles on my new tranmisson and monster stage 2 clutch with 28# flywheel and ...
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    So I have finally put 500 miles on my new tranmisson and monster stage 2 clutch with 28# flywheel and new slave cyldiner. Original master cylinder still in.
    Revshift Blue Motor mounts in and also have the Revshift transmisson insert.
    Been holding back for a while now
    Decided to open her up on a back road. No problem going into 2nd but when I went to 3rd I had a slight grind and the same going into 4th.
    I've got a feeling this is clutch related and not the trans.
    Seems I've read somewhere about people drilling / opening up clutch lines and such; but that did not relate to our cars.
    Any new feedback on issues like this? Trans feels real solid and shifts great, but it is nice to get into the RPM's every once in a while.
    and yes I had the clutch all the way in.
  2. #2
    69stangscj's Avatar
    69stangscj is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V sedan, 69 Mustang Mach I
    Jul 2013
    Dayton Ohio
    329
    Re: New Trans + Monster Stage 2 Clutch w/ 28# Flywheel - Slight Grind into 3rd & 4th.
    Quote Originally Posted by SevillianSTS View Post
    Not sure I understand this?
    Maybe you have air in your line and need to bleed the clutch?
  3. #3
    Aug 2005
    Northern IN
    1,006
    Quote Originally Posted by 69stangscj View Post
    Type cts-v drill mod into google. Has to do with a restriction in the master to slave hydraulic line. From what I find it is more common in older camaros though.
    Being I have a remote bleeder I'll bleed it again, but I don't think this is the issue.
    I'm just trying to read into this rather than go out and do a couple WOT's and harm the new trans.
  4. #4
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Sounds like clutch needs bled.
