05 ctsv cranks but wont start after motor build.
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Like Tree3Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, 05 ctsv cranks but wont start after motor build. in Cadillac CTS-V Series Forum - 2004 - 2007; I did heads, cam, 42 lb injectors, and computer reflashed on my 05 V and have everything back together where ...
    CTSTONY is offline Cadillac Owners Member
    Automobile(s): 2005 CTSV
    Jul 2013
    33
    9
    I did heads, cam, 42 lb injectors, and computer reflashed on my 05 V and have everything back together where its supposed to go and the motor will crank and crank but will not light off. The DVD screen, some times when i turn the ignition on but not every time, will tell me check oil level. According to the dip stick oil is full. After the good amount of cranking attempts the exhaust does not smell like fuel or anything has been emitted into the exhaust. Also when the motor was out of the car i had the car at the body shop and they left the key in the run position the whole time and it ran the battery down COMPLETELY and sat that way for about a month, dont know if that would do anything but thought i would throw that info in. Thank you, Andrew
  2. #2
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,786
    Re: 05 ctsv cranks but wont start after motor build.
    Do you have fuel pressure, and do you hear the pump running?
    I would suspect the reflash.
    You might have wiped out the crank position sense.
    Do a search for the crank relearn procedure.
    Check for spark.
    Just disconnect a plug wire and hold it near the block (not by hand!) while someone cranks the motor.
  3. #3
    Jul 2013
    33
    9
    Ok I will check and get back with the results.
    Also the crank re learn procedures i found seem to require the motor to run.
  4. #4
    Nov 2004
    8,786
    I remember when a reflash was done on a few other V's a bit was not set and it would not start or run.
    Was your flash done via EFI?
    Before it gets real involved, I would reflash the PCM back to whatever it was and see if it starts.
  5. #5
    Jul 2013
    33
    9
    I do not know if it was done via EFI. It was done by EPS, the place that did the cam pacakge.
    And what do you mean by "a bit was not set" sorry im still in the learning curve of fuel injected vehicles.
    And re flashing the PCM back to stock would require shipping it half way across the US. :\
  6. #6
    Nov 2004
    8,786
    By "bit not set", is programming speak.
    EPS should know what they are doing, so I don't think they screwed up your PCM.
    EFI is a program to tune by.
    Check for spark and fuel pressure.
    Fuel pressure you can tell by hearing the pump run when ignition is turned on, under passenger rear wheel.
    You sure you have the coil packs plugged back in and plug wires inserted correctly?
    Hard to think that you got all 8 wrong.
  7. #7
    Jul 2013
    33
    9
    I just checked the for fuel and the fuel pump does come on when you turn on the ignition, but does sound like it shuts off once it builds pressure ( which i would assume is normal) correct me if im wrong.
    I checked for spark and there is no spark when i crank the motor over.
    all the coil packs are plugged in, i checked thoroughly.
  8. #8
    Nov 2004
    8,786
    I know you aren't gonna like hearing this, but that is why I have two PCM's now.
    You need to check for 12 volts at the coil packs.
    Just turn on the ignition and check at the plug in.
    If it isn't there, you have some troubleshooting to do.
    If it is there, the PCM isn't firing them off. IMO
  9. #9
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,813
    Mod Hell strikes again.
  10. #10
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    I'm guessing is a ground not commenced right... First thing my dad taught me on diesels if something like that is happening is to check the ground connections and wiring
  11. #11
    Jul 2013
    33
    9
    all the grounds are hooked back up where i took them off of.
  12. #12
    Nov 2004
    8,786
    Here is a link to the fuse box.
    http://www.cadillacfaq.com/faq/answe...ox/fusemap.jpg
    As you can tell, each pack is fused separately.
    I would check for 12 volts here and at the coil packs first.
  13. #13
    Jul 2013
    33
    9
    Would it make a difference if the driver side coil packs got put on the passenger side and passenger on the driver side?
    ok i will check it out
  14. #14
    Jul 2012
    Wildomar, CA
    31
    976
    Quote Originally Posted by CTSTONY View Post
    The coil packs are interchangeable.
  15. #15
    Jul 2013
    33
    9
    I just checked and there is power to the coil packs and there is power to the fuses...
    There is also power to the injectors as well
  16. Remove Advertisements
