Transmission grind under hard accel
Results 1 to 13 of 13
2004-2007 Cadillac CTS-V General Discussion Discussion, Transmission grind under hard accel in Cadillac CTS-V Series Forum - 2004 - 2007; My trans grinds when shifting Into 3rd only at high rpms or hard accel but when normal driving it shifts ...
    lx5.0 is offline Cadillac Owners Member
    Jun 2013
    29
    72
    My trans grinds when shifting Into 3rd only at high rpms or hard accel but when normal driving it shifts fine no grinds. I also noticed one time I had a hard time shifting into reverse gear would just not go In, is my trans messing up already the car is at 60k
    Sent from AutoGuide.com Free App
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,156
    Re: Transmission grind under hard accel
    The first item on the trouble shooting chart for any kind of gear shifting issue is to flush and bleed the hydraulic clutch system.
  3. #3
    Jun 2013
    29
    72
    That was the first thing I did cuz I noticed my pedal would stick to ground on hard accel so I bled it but it still does it but pedal don't go all the way down anymore but I did notice my pedal got a lil stiffer with the bleedin which felt way better... I also noticed that sometimes my gears grab nice n somtimes they feel sloppy when shifting like the shifter feels loose
  4. #4
    Jun 2013
    29
    72
    And I've been searching around n I don't know were to start I've seen a lot of people have similiar problems from shifter bushings to trans mount to slave cylinder
  5. #5
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,156
    If the clutch hydraulics are not an issue, the GM trouble shooting procedure calls for two tests. One is to establish whether the transmission can be shifted from neutral to any other gear with the motor not running (static test). The second is establish whether the transmission can be shifted from neutral to any other gear with the motor running (dynamic test). If it fails the static test the issue is likely with the shifter, or transmission mounting. If it fails the dynamic test, the issue is likely inside the transmission.
    Having said all that, the pedal sticking to the floor symptom can indicate a failing clutch pressure plate.
  6. #6
    Jun 2013
    29
    72
    Alright ima give it a try let c wat happens
  7. #7
    Jun 2013
    29
    72
    Well I tried both test n it shifted fine every gear goes in fine hopefully its just a shifter bushing problem or mount ima start shopping around for a short shifter wat do u all recommend
  8. #8
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,156
  9. #9
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    good luck with that, I've got another thread going with similar issues. Had a reverse grind; dealer pulled the trans, rebuilt and now they say 3rd grinds at higher RPM's... so now I wait....
  10. #10
    Jun 2013
    29
    72
    Well hopefully its nothing big if I change my trans fluid wat do u all recommend
  11. #11
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,156
    Any major brand meeting the Dexron III specification.
  12. #12
    Jun 2013
    29
    72
    And I'm really interested in that pinsuoff shifter but that Link got me no wer
  13. #13
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,156
    Quote Originally Posted by lx5.0 View Post
    I just bumped the thread to which the link pointed - it is the thread to discuss orders for that shifter.
  14. Remove Advertisements
