Vibration / noise at certain RPM
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Like Tree1Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Vibration / noise at certain RPM in Cadillac CTS-V Series Forum - 2004 - 2007; I have started to get a vibration and a humming sound that starts at about 2100RPM. It doesnt follow speed ...
    av8erdunn is offline Cadillac Owners Member
    Apr 2012
    34
    40
    I have started to get a vibration and a humming sound that starts at about 2100RPM. It doesnt follow speed I dont think because it does it in any gear. Its odd because if I am cruising at 75 around 2300-2500 RPM it will constantly do it until I let of the thottle; then it quits. But once I apply throttle again it starts right back. Its like under a loaded condition is the only time it happens. It gradually gets louder and a little worse vibration as RPM increases but I think it finally gets to a certain frequency then it just maintains that frequency.
    Any ideas?
  2. #2
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    40
    594
    Do you have the stock clutch? Any mods? Stock mounts?
  3. #3
    Apr 2012
    34
    40
    Re: Vibration / noise at certain RPM
    Its the stock clutch, and my motor mounts were just replaced with new OEM mounts. Only mods are a corsa exhaust coupled to Kooks headers and cats and a custom tune.
    moarofthis likes this.
  4. #4
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,833
    I was thinking mounts, too, until I saw that last post.
    If it's not exhaust related (where the flow is related to load or throttle position but doesn't fit the "vibration" described above), I'm wondering what else it could be if it's not related to anything downstream of the flywheel (since it "doesn't follow speed").
    Anybody else?
  5. #5
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,722
    Quote Originally Posted by av8erdunn View Post
    Any ideas?
    Hello av8erdunn,
    I see you have gotten some advice from other members on here. Have you been able to find the cause of this vibration and humming sound? If you want to further discuss your concern and are thinking about taking it in for a diagnosis, private message me so we can continue our interaction.
    Sincerely,
    Laura M.
  6. #6
    LS6Steve is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Jun 2011
    San Jose, CA
    132
    Have you checked your transmission mount?
  7. #7
    Apr 2012
    34
    40
    I have not looked at it but I have had a bad transmission mount before and i could punch the throttle and let off quickly and I would get a BANG, this one didnt do that. I will look this afternoon though.
  8. #8
    Jun 2011
    San Jose, CA
    132
    I've had cars do that too, but usually more so when there is a ripped top-mount type. With these bottom mount ones, the seem to fail differently. i just replaced a bad one and it sounded IDENTICAL to a bad input bearing issue, there was a knock with every input shaft RPM. Now it's gone, smooth as butter.
  9. #9
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,213
    ...a humming sound that starts at about 2100RPM. It doesnt follow speed I dont think because it does it in any gear. Its odd because if I am cruising at 75 around 2300-2500 RPM it will constantly do it until I let of the thottle; then it quits. But once I apply throttle again it starts right back.
    These quoted words, viewed alone, would be a description of the infamous differential whine. Whether it is a "whine" or a "hum" could be a matter of semantics. The differential whine can be initiated and ended with light on/off application of throttle particularly at cruising speeds.
  10. #10
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,833
    OP, is the sound coming from the motor area or from the rear end? Can you tell?
    As darkman points out, a "whining" sound would indicate your diff. Mine whines/hums a bit, but doesn't vibrate.
  11. #11
    ImEpayne is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac CTS-V
    Feb 2013
    North Syracuse, NY
    27
    71
    I've got the same issue in my '06. mine is definitely a vibration at the same rpm's regardless of speed. Now I know I need to do my Harmonic Balancer. I've been under the assumption that this is the cause of the vibration.
    Let us know what you figure out.
  12. #12
    Apr 2012
    34
    40
    Can't really tell where its coming from. If it was diff whine, would it have not been there in the morning but there in the afternoon? Would it also cause a vibration? But then again it was doing it at the same rpm in second as it was in fifth. Very odd!!!!!!
    Quote Originally Posted by ImEpayne View Post
    How do you know you need to change your harmonic balanced?
  13. #13
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,213
    The differential whine is not accompanied by vibration. If the issue varies with engine rpm as opposed to road speed, it presumably is an issue upstream of the transmission.
  14. #14
    Heavybody is offline Cadillac Owners Fanatic
    Automobile(s): 04 CTS-V and 94 SLS
    Oct 2005
    NH
    149
    Mine has a similar whine issue ... Fold down the rear seat or armrest to make sure the whine or hum is the diff it should be much louder and noticeably from the rear of the car. I ignore the noise as I assume it's the notorious whine... Or normal...lol
    Good luck with the vibration I had one similar to what you describe and when I replaced my tires it went away almost all the time... (It was so bad I avoided highways for quite some time) rebalancing your wheels is a possible inexpensive solution if you have some miles on your tires...
    When the vibration does come back I can usually down shift to 5th or play with the throttle to get the drivetrain to adjust to a smooth place again. Not sure of a solution yet as I haven't had much time to address the issue but I have found ways to make it tolerable
    Keep us posted!
  15. #15
    Mar 2010
    Detroit, USA
    12,722
    Hello ImEpayne,
    I apologize that you are experiencing the same issue with your CTS-V. Have you taken your vehicle to the dealership to have it diagnosed? If you would like our assistance in working with the dealership as well regarding this issue, please private message us. Thank you very much for taking the time to read my post.
    Gregory W.
    Cadillac Customer Care
  16. Remove Advertisements
