Help please
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By thebigjimsho
2004-2007 Cadillac CTS-V General Discussion Discussion, Help please in Cadillac CTS-V Series Forum - 2004 - 2007; Hi guys, I'm new to this forum. My name is Jennifer and I'm having a problem with my car. I ...
    jmarie__ is offline Cadillac Owners Member
    Jun 2013
    8
    Help please
    I inherited a 2007 Cadillac CTS V6 from my father a few months ago so I don't know too much about this car. I had the tires changed, and put in new rotors and new brakes last week.
    Today my boyfriend started the car to go to work and he called me and let me know it was shaking, which it never does. I went outside and the temp gauge was already in the middle (after only about 3 minutes of the car turning on) ... Then the check engine light came on. The car has no leaks and the info system only says to check window washer fluid which clearly isn't the problem. The car never overheated but continued to shake. Can anybody help me out??? Thank you!
  2. #2
    robojesus is offline Banned
    Automobile(s): of
    Aug 2012
    gay
    184
    Re: Help please
    sounds like a head gasket.
    what was the ambient temperature outside?
    are any of your radiator fans broken?
  3. #3
    Jun 2013
    8
    Fans are working and it was about 70 degrees, maybe a little less. The head gasket crossed my mind actually cuz something similar happened to my civic a while ago.
  4. #4
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,165
    Re: Help please
    There are many possibilities. The error code that set the check engine light will indicate the nature of the problem. Buy a scanner from an auto parts store (go to a shop) and determine the code.
  5. #5
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,224
    Re: Help please
    Sorry for your loss. Two suggestions to help you get help:
    (1) Put some detail in the title of the thread. "Help please" won't draw in as many views as "Help - 2007 CTS excessive shaking at idle" or something similar that will give folks an idea what the thread is about.
    (2) If the car is a V6, you might have better luck in the forum for the 1st generation V6 cars.
    With that said, was the car idling at the normal RPM? Did you drive it all, or just try taking it out of Park and into Drive to see if it changed behavior?
    There are a variety of things it could be, but without a Check Engine Light and associated code, it's hard to diagnose over the intarweb. It might take a bit of running for the CEL to pop on.
    Edit: Looks like you anticipated my 2 suggestions - http://www.cadillacforums.com/forums...s-shaking.html
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  6. #6
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    Usually autozone or similar auto parts store will check the error code for you free of charge, if you do not have a scanner yourself. Post what code is causing the light.
  7. #7
    Automobile(s): of
    Aug 2012
    gay
    184
    Re: Help please
    to me, it seems like a head gasket. the leak is causing a misfire, and the head gasket is causing the overheat.
  8. #8
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Quote Originally Posted by AAIIIC View Post
    But she's a girl!
    sgtdestruction likes this.
  9. #9
    Faber is offline Cadillac Owners Fanatic
    Automobile(s): None :(
    Aug 2011
    Cincinnati, OH
    38
    407
    Re: Help please
    lol...I find it funny how nice folks are when its a girl posting vs. a guy...
  10. #10
    Becker's Avatar
    Becker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 black with tan V
    May 2013
    31
    391
    Re: Help please
    agreed.. i think most would assume a guy "know" exactly what to do....always comical to see someone get they're head bitten off for asking for assistance with a problem in the wrong "format"
  11. #11
    Mn800r's Avatar
    Mn800r is offline Cadillac Owners Fanatic
    Automobile(s): 11 V Coupe, 05 V Mod'd, 91 Fatboy,98 Ultra classic, 07 Tahoe
    Jul 2012
    Scandia MN
    50
    383
    Re: Help please
    I think jimbo spooked her..
  12. #12
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,362
    Re: Help please
    Jimbo spooks all lol.
  13. #13
    mberisha's Avatar
    mberisha is offline Cadillac Owners Connoisseur
    Automobile(s): '11 Black Escalade AWD & '06 Black CTS-V
    Aug 2009
    Aviano, Italy
    38
    1,898
    Re: Help please
    He sp00ked me too......
  14. Remove Advertisements
