New Bushings but still shakes, any ideas?
Results 1 to 11 of 11
2004-2007 Cadillac CTS-V General Discussion Discussion, New Bushings but still shakes, any ideas? in Cadillac CTS-V Series Forum - 2004 - 2007; My 2004 V has newly installed revshift blue motor mounts, and previously installed creative steel trans mount & rear diff ...
    voodoochikin04 is offline Banned
    Automobile(s): 2003 cts, 2004 Cts-v
    Nov 2012
    Norfolk, NE (eastern Nebraska)
    31
    316
    My 2004 V has newly installed revshift blue motor mounts, and previously installed creative steel trans mount & rear diff bushing. Prior to the revshift mounts, (shot gm MM) the engine would buck when taking off hard, and would shake quite a bit when shutting down. Now even with the new mounts in, it still shakes and rattles quite a bit when I shut it off. Im questioning this issue because my friend also installed new Revshift blue mounts to replace his worn out gm MM, and his shake went away completely. Any ideas?
  2. #2
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,372
    Re: New Bushings but still shakes, any ideas?
    Bad install of the mounts? Just shooting that out there.
  3. #3
    Nov 2012
    31
    316
    lol.. could be a possibility, but its pretty straight forward. 100% sure all bolts were tightened down. unless something came loose. Ill report back what I find.
  4. #4
    Skidmarcx's Avatar
    Skidmarcx is offline Cadillac Owners Fanatic
    Automobile(s): NONE!
    May 2011
    Phoenix, AZ
    39
    356
    Sounds like possible flywheel
  5. #5
    Nov 2012
    31
    316
    Really? because SOME mornings I have a slight ticking sound when I start up, and it will stop if I touch in the clutch a hair, but also goes away after a minute on its own.. What issues does a bad flywheel have? I have zero experience with dual mass flywheels.
  6. #6
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    The weights can stick, leading to imbalance, and could possibly lead to the symptoms you're showing. Darkman, what say ye?
  7. #7
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    Dieseling on shutdown can be caused by motor mounts (already eliminated here); a worn dual mass flywheel (already mentioned above) which is a spring loaded device - the springs weaken, but usually only after pretty high mileage; or a leaky fuel injector, which continues to flow fuel into the cylinder after shutoff - a leaky injector can also "tick" under normal operation.
  8. #8
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    Quote Originally Posted by darkman View Post
    So is the tick from a leaky injector at idle or will it get more pronounced as rpm increases like a header leak? What is the life expectancy of an injector? I have been chasing a noisy valve train but feel this could be the answer.
  9. #9
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    A leaky injector, or a noisy healthy injector for that matter, is more likely to tick when under worked, which means it is more load sensitive than rpm sensitive. (For example, revving a motor in neutral involves high rpm but not a high load level.)
  10. #10
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    Any cure? Or just deal with the tick?
  11. #11
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    Quote Originally Posted by JFensty View Post
    It is matter of testing the fuel system to see if there is a leaky injector; isolating the leaky injector if there is one; and replacing it.
    See attached.
  12. Remove Advertisements
