Fuel line disconnect tool for '06 CTS V
Results 1 to 6 of 6
2004-2007 Cadillac CTS-V General Discussion Discussion, Fuel line disconnect tool for '06 CTS V in Cadillac CTS-V Series Forum - 2004 - 2007; I have a '06 CTS V I just ought 2 weeks ago and I want to change the fuel filter. ...
    06VaporTrail's Avatar
    06VaporTrail is offline Cadillac Owners Member
    Automobile(s): 06 CTS V
    Jun 2013
    Jacksonville Fl
    47
    48
    I have a '06 CTS V I just ought 2 weeks ago and I want to change the fuel filter. What tool is required to disconnect the two lines going into the fuel filter? Thanks in advance for your help.
    Randy
  2. #2
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    67
    13,804
    Re: Fuel line disconnect tool for '06 CTS V
    Hi, Randy! I have one buried in a box in an upper loft in my garage so can't help you there, but I do know AutoZone has 'em.
  3. #3
    seeyouinajif is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V
    Apr 2013
    Boston, MA
    30
    132
    This was a pain for me, none of the tools I had worked. Ended up buying a universal scissor type disconnect tool and then had to grind some off so it would fit between the filter and the fitting. I'd post a link but I'm on my phone, it was the cheap $4 one that looks like an x and has four different tabs for different size lines.
  4. #4
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,358
    Where is the fuel filter? Also how often should you change it out?
  5. #5
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,156
    See attached.
    The fuel filter has no routine replacement interval, it should only be replaced if restricted.
  6. #6
    odla's Avatar
    Nov 2006
    miami ,Fl
    2,358
    Good to know thanks!
  7. Remove Advertisements
