2 concerning events in a 5 minute drive
Results 1 to 6 of 6
Like Tree1Likes
  • 2 Post By trhs75
2004-2007 Cadillac CTS-V General Discussion Discussion, 2 concerning events in a 5 minute drive in Cadillac CTS-V Series Forum - 2004 - 2007; All is fine and dandy on my drive to Arby's on my lunch break. About a 5 minute drive from ...
    ImEpayne is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac CTS-V
    Feb 2013
    North Syracuse, NY
    26
    71
    All is fine and dandy on my drive to Arby's on my lunch break. About a 5 minute drive from my place of work. After it get my food and get back in my V i start her up... There is SEVERE knocking for half a second to a second and then it goes away. I listen carefully and drive different ways to try and make it knock again. doesn't do it. THEN almost back to work at a stop light. The light turns green and as I start off it kicks me out of first gear with an array of grinding. Doesn't do it again at any of the following stops.
    2006 with 80k. I am hoping the popping out of gear is curable with revshift MM and tranny mount. which will be in order very soon if it acts up again. But the knocking... It's not low on oil... but it does consume probably 1 qt every month and a half or so. Also I'm pretty sure my harmonic balancer is bad. (vibrates according to rpm usually in 5th gear aroung 60 mph) Is it possible a pretty bad pulley could slop around or was this internal.
    I do have a pretty solid extended warranty.
    Any insight?
    Thanks,
    Eric
  2. #2
    robojesus is offline Banned
    Automobile(s): of
    Aug 2012
    gay
    184
    Re: 2 concerning events in a 5 minute drive
    blow the bitch up and get the warranty to cover it.
    my guess? you have a collapsing/collapsed lifter that pumps back up and works after a bit.
  3. #3
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,161
    See attached.
  4. #4
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    The knocking on startup sounds like a dual mass clutch with sticking weights. The slipping out of gear, not sure...
  5. #5
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by ImEpayne View Post
    Any insight?
    Thanks,
    Eric
    Hello ImEpayne,
    Have you experienced the knocking concern again? Please keep us updated! I would like to offer you my assistance in working with the dealership if you are willing to take it in. If it happens again and you would like to see if the dealership would be able to diagnose the concern, please private message me your name, contact info, VIN, mileage, and dealership you would like to work with. Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
  6. #6
    trhs75 is offline Cadillac Owners Fanatic
    Apr 2009
    316
    You know, mine has popped out of first gear occasionally in each of two trannies. Keep in mind I've been driving a stick for over forty years and I've never had a problem with this, but I have noticed that occasionally I don't get it completely into first gear at a stoplight, and that's when this occasionally happens. I can't believe I'm missing the gear by not placing the shifter correctly, but that's what happens. Sometimes it's quite a bang when the shift lever pops out of gear and into neutral. I know you won't believe you're doing this -- I didn't believe I was doing it either!!
    ImEpayne and ImEpayne like this.
  7. Remove Advertisements
