Strange sound from both wheels in front *please help!!!
Results 1 to 13 of 13
2004-2007 Cadillac CTS-V General Discussion Discussion, Strange sound from both wheels in front *please help!!! in Cadillac CTS-V Series Forum - 2004 - 2007; So I have a 2005 V that I recently purchased and have a strange noise from both front wheels. It ...
    jmsweetv's Avatar
    jmsweetv is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Apr 2013
    Westfield, Indiana
    38
    37
    So I have a 2005 V that I recently purchased and have a strange noise from both front wheels. It sounds like there is a little rock stuck in the tire and makes a constant clicking sound that get faster as the wheels spin faster. I have a hard time describing what it sounds like....it like when I was little and put a playing card by the spokes of my bicycle wheel to make noise. When I break it is still there but sound is a little deeper in sound. I had my mechanic look at it when he was doing my alignment and couldn't see anything that was obstructing anything. Its not a grinding or a squealing noise. Something sounds like it is clipping something else.
    Anyone hear of this? It doesn't matter if I turn or straight. I cannot feel anything in the steering wheel or brake pedal. It does not sound like a wheel bearing. Could it be the tires? My tires are worn on the edges a little but 8/32 tread Goodyear rsa.
    I've tested everything and look and cannot figure it out. I've had no success searching this forum or others.
    Please help!!!!!
  2. #2
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,365
    Re: Strange sound from both wheels in front *please help!!!
    Nail in the tire? Did it make this sound before the alignment?
  3. #3
    gruvent is offline Cadillac Owners Member
    Automobile(s): 2006 CTS-V
    Jul 2012
    Merritt Island, FL
    51
    Broken tps?
  4. #4
    jmsweetv's Avatar
    Apr 2013
    Westfield, Indiana
    38
    37
    No nail and tps is fine. Yes, it did make the noise pre alignment.
  5. #5
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Have you rotated the tires? If so, does the noise move with the tires?
  6. #6
    seeyouinajif is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V
    Apr 2013
    Boston, MA
    31
    132
    I would check again for nails. Sometimes the heads wear off and they can be difficult to see. Also listen to darkman, rotate the tires to see if noise moves.
  7. #7
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,320
    Rotating the tires was my first thought, too.
    Have you pulled a wheel off and spun the rotor/hub to see if there's any noticeable sound?
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  8. #8
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,695
    Quote Originally Posted by jmsweetv View Post
    Please help!!!!!
    Hello jmsweetv,
    I apologize for the clipping sound your vehicle is experiencing. I am sorry I cannot offer any technical advice because I am not a certified technician. If you are going to get a mechanic or certified technician to look at your vehicle again, let me know, because I do care about a solution for your issue. If there are other questions or concerns that arise, don't hesitate to contact us.
    Sincerely,
    Laura M.
  9. #9
    jonathan2169's Avatar
    jonathan2169 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V and 2004 CTS-V
    Apr 2013
    40
    84
    Quote Originally Posted by Cadillac Cust Svc View Post
    Hello jmsweetv,
    Sincerely,
    Laura M.
    @Cadillac Cust Svc a bot?
  10. #10
    Mar 2010
    Detroit, USA
    12,695
    Quote Originally Posted by jonathan2169 View Post
    Hi jonathan2169,
    No, definitely not a bot! I am here to assist you in any way that I can. Is there anything I can help answer for you?
    Regards,
    Laura M.
  11. #11
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    pwned!
  12. #12
    jmsweetv's Avatar
    Apr 2013
    Westfield, Indiana
    38
    37
    Yes, rotated tires and still there. I can take the tires out of the equation. Spun the rotors with wheel off and no sound...so could be when weight of car is on the hub.
  13. #13
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    At the risk of stating the obvious, the only parts at the front of the car rotating at the same speed of the tires (as indicated by the original description of the symptom) are the hubs (bearings) and rotors with the spindle and brake pads being candidates by association. The only possibility that comes to mind is something like a loose fender well hitting the tire.
  14. Remove Advertisements
