Clutch switch
Results 1 to 9 of 9
2004-2007 Cadillac CTS-V General Discussion Discussion, Clutch switch in Cadillac CTS-V Series Forum - 2004 - 2007; Check engine light on because of clutch position sensor. I looked at it and its all loose. Check out picture, ...
    gruvent is offline Cadillac Owners Member
    Automobile(s): 2006 CTS-V
    Jul 2012
    Merritt Island, FL
    51
    Clutch switch
    Check engine light on because of clutch position sensor. I looked at it and its all loose. Check out picture, is it broken or did it come loose? Can't tell.
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,213
    Re: Clutch switch
    The clutch position switch looks like this:
    http://www.rockauto.com/catalog/moreinfo.php?pk=335772&cc=1432727
    See attached.
  3. #3
    Jul 2012
    Merritt Island, FL
    51
    Re: Clutch switch
    That's the same part in the photo, I just cropped it to the end that was suppose to be attached to the firewall? This switch is sliding loosely over the clutch shaft. Its kinda hard to get up in the dash to figure out how it suppose to connect.clutch.PNG
  4. #4
    Jul 2012
    Merritt Island, FL
    51
    Re: Clutch switch
    Your service PDF shows some tabs or something on the back side, I will try messing with that. Thanks Darkman
  5. #5
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,377
    Re: Clutch switch
    After you disconnect the wire that goes to it it should just snap out if i remember right. Oh btw. when putting the new one back in it was a pain to get the slider under the tab on the rod that it attaches to. What i did was i got a paper clip. Made a L shape to push the slide on the new sensor down. I wedged the paper clip enough to keep it in the down slid position. Snapped the sensor back on and the pulled the paper clip out. I don't know how to describe it any better. You may see what i am talking about when you go to do it. Hope that kind of helped.
  6. #6
    Jul 2012
    Merritt Island, FL
    51
    Is it suppose to be loose on the clutch shaft? Or mounted to that ring on the firewall?
  7. #7
    odla's Avatar
    Nov 2006
    miami ,Fl
    2,377
    Re: Clutch switch
    If i remember right yes loose. Able to slide up and down the shaft. WHen working it will be pushed down. The sensor has a spring in it. That is what usually is bad.
  8. #8
    Jul 2012
    Merritt Island, FL
    51
    Odla, you were right. Springs were broken. It was easy to take apart. Went down to ace hardware and replaced the springs. Cleared the pending codes and works good now. Fixed my cruise control problem also.
  9. #9
    odla's Avatar
    Nov 2006
    miami ,Fl
    2,377
    Re: Clutch switch
    Glad we were able to help you out.
  10. Remove Advertisements
