coolant temp artificially hot?
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V General Discussion Discussion, coolant temp artificially hot? in Cadillac CTS-V Series Forum - 2004 - 2007; I was driving my V today in hot weather, and running the A/C. It's about 92 out right now. I ...
    robojesus is offline Banned
    Automobile(s): of
    Aug 2012
    gay
    184
    I got "Coolant hot idle engine", so I shut my AC off, and coasted, and almost immediately the temperature went down to the middle line where it normally stays.
    When I built my 408, i put this thermostat in the water pump. http://www.summitracing.com/parts/mr...FQSZ4AodixoAPw
    the stem that holds the thermostat is a little longer than the stock one, but it was just pushed down by the rest of the water pump, to stock location, so what i'm saying here is, although the stem is longer, the opening mechanism is still the same throw. The car was running at fine temperatures when it was in the 60's... the only thing that has changed is I pulled my radiator out to put a new A/C compressor in.
    Anyone else experienced any "fluke" overheats, or is this something I need to figure out?
  2. #2
    Wingsfan4life's Avatar
    Wingsfan4life is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V Black Raven
    Aug 2011
    Brooklyn Center, Mn
    46
    232
    I got a couple last summer...changed the coolant temp sensor and its been fine since
  3. #3
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,156
    Re: coolant temp artificially hot?
    And coolant temp sensors are almost free. ($7-$20).
  4. #4
    Automobile(s): of
    Aug 2012
    gay
    184
    I guess I should have noted that I just had a friend take the rad out... turns out he left the fan unplugged. Meh.
  5. #5
    Aug 2011
    Brooklyn Center, Mn
    46
    232
    I was gonna suggest checking fan plugs as well...my primary fan came unplugged a clue times.. *after coolant temp sensor replacement* weirdest thing ever too..had to use a zip tie on it..lol
  6. Remove Advertisements
