LS6 Oil Leak Passenger Side - Page 2
Results 16 to 30 of 34
Like Tree1Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, LS6 Oil Leak Passenger Side in Cadillac CTS-V Series Forum - 2004 - 2007; Try re-torque them at the right ft lbs just to check. That way you cant over do them if it ...
  1. #16
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,362
    Re: LS6 Oil Leak Passenger Side
    Try re-torque them at the right ft lbs just to check. That way you cant over do them if it is still to spec.
  2. #17
    PISNUOFF Guest
    My front main seal always looked like it was leaving from that spot. Maybe yours has eaten into the balancer like mine did, twice.
  3. #18
    repenttokyo is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Jan 2009
    1,171
    I was underneath again tonight and I took some pictures.
    Further analysis reveals that the leak might be higher than I thought. You can see both the passenger side, where it is really bad, and a little bit above the oil filer on the driver's side, in these shots.
    Any opinions or help would be appreciated!
  4. #19
    PISNUOFF Guest
    What's it look like at the top, behind the intake manifold?
  5. #20
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Havent read previous posts, but it might be a motor mount that broke. The fluid looks brown when it dries
  6. #21
    Jan 2009
    1,171
    Quote Originally Posted by lollygagger8 View Post
    I am running 80a poly mounts from revshift.
    Quote Originally Posted by PISNUOFF View Post
    I will take another look tonight, but after the track last night it looked dry. Blocked PCV maybe? It only seems to come out when the engine is running, I've had it up on a lift and washed the underside, and half a day sitting revealed no leak. Driving the car got it going again.
  7. #22
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,816
    I'm turned around a bit. Is that anywhere near the dipstick tube?
  8. #23
    Jan 2009
    1,171
    It's on the same side of the engine as the dipstick tube, but the tube itself appears to be dry at the top - last time I checked.
    It happens during normal driving, so I don't see how it could be blowing out the tube - if it was exclusively on the track, then maybe, but during normal driving?
  9. #24
    robojesus is offline Banned
    Automobile(s): of
    Aug 2012
    gay
    184
    it could blow out of the tube if you have a clogged PCV line (ask me how i know).
    i'd also take that cover off and check for oil in the bellhousing.
  10. #25
    Jan 2009
    1,171
    Quote Originally Posted by robojesus View Post
    which cover specifically?
  11. #26
    Automobile(s): of
    Aug 2012
    gay
    184
    Quote Originally Posted by repenttokyo View Post
    There's the two little black covers that go on either side of the bell housing, at between 8-9 o'clock and 3-4 o'clock. One is the trim to keep water from getting into the bell from the starter, the other goes over the other side so they can generically use the engine-trans on other cars and easily swap starter locations. I have a feeling like you might have a little oil blowing through there, although I could definitely be wrong
  12. #27
    Apr 2008
    Indiana
    4,913
    Ok I saw the pics....sorry I didn't look before.
    When you put the oil pan back on you have to use some RTV in the corners where the timing chain covers connects to it. Either that is missing, or not enough, or it was never cleaned off when reinstalled. This is a common spot that has the potential to leak.
    The oil pan bolts do not take much TQ at all (106 INCH lbs IIRC) they could also be over or under torqued.
  13. #28
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,816
    Your other pics were outstanding. Can you post up more now that you seem to have it pinpointed?
  14. #29
    Jan 2009
    1,171
    Back everyone - sorry I bought a house last week and it's been keeping me away from the car.
    I think it's the oil pan - that's what seems to make the most sense so far. After a track session this week I examined the top of the engine, but I couldn't find any oil anywhere, really, except for what looked like a bit of older staining near the front of the passenger side valve cover. I am going to try re-gasketing the oil pan and see if that helps. I have a few weeks before my next track date, so that should give me time to do it.
    I really appreciate everyone's help on tracking this down. I hope that will solve my problem.
  15. #30
    2007ThunderV's Avatar
    2007ThunderV is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts v
    Jul 2011
    482
    I had a oil pan done on mine looked wet in the same areas
  16. Remove Advertisements
