Retaining DIC with aftermarket head unit
Results 1 to 3 of 3
2004-2007 Cadillac CTS-V General Discussion Discussion, Retaining DIC with aftermarket head unit in Cadillac CTS-V Series Forum - 2004 - 2007; Quick question on this - I've searched extensively and found where it is quite possible to do this with a ...
    SunsetEffler is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V
    May 2013
    34
    16
    Quick question on this - I've searched extensively and found where it is quite possible to do this with a donor head unit from a stock CTS, but all of the write ups, guides, etc. are always on a base model CTS. My question is does this also work for the CTS-V? It seems logical that that all of the DIC functions that would normally be hooked up to the stock nav unit would also work through the amber LED display but I want to be sure before I start buying parts.
    Thanks for the input!
  2. #2
    mackey is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Black
    Sep 2012
    172
    You need the non-V/nav radio and have it reprogrammed to accept your VIN if you're going with aftermarket to replace the V unit and retain DIC as well as personalization options.
    AFAIK they plug in the same so there's no compatibility issue as non-Vs also had the nav option
  3. #3
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,787
    Re: Retaining DIC with aftermarket head unit
    You are gonna lose the communication for the driving functions through the OEM radio controlled by the steering wheel switches.
