Rear Diff???
Results 1 to 7 of 7
2004-2007 Cadillac CTS-V General Discussion Discussion, Rear Diff??? in Cadillac CTS-V Series Forum - 2004 - 2007; Have an 05 cts-v. Have the clunk and have ordered all revshift has for us. Wondering if I should replace ...
    gregj1006 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Aug 2009
    45
    406
    Rear Diff???
    Have an 05 cts-v. Have the clunk and have ordered all revshift has for us. Wondering if I should replace rear diff while the revshift stuff is going in and if so will this one work for my car? Will the PCM programming be necessary?
    http://www.ebay.com/itm/2008-CADILLA...86b9ff&vxp=mtr
    Appreciate any/all replies
  2. #2
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Re: Rear Diff???
    I don't know if it will fit or not. I would check the part number with a GM parts person. Assuming it will fit, I think the only reprograming would be for the speedometer/odometer. I also suspect, but do not know for sure, that any shop with a GM Tech II Scanner can reset the final drive ratio. Finally, it may be inherently nosier assuming the 3.91 ratio is achieved using 43-tooth ring with an 11-tooth pinion gear. (Our 3.73 has 41-tooth ring with an 11-tooth pinion.)
  3. #3
    QwkRhino's Avatar
    QwkRhino is offline Cadillac Owners Member
    Automobile(s): None
    May 2012
    O.C.
    40
    64
    Re: Rear Diff???
    Yes it would fit, but you would have to change the pinion flange to part #19179934 and cut off about a inch off the tip of the pinion in front of the diff. Easy to do. I just went this route keeping the 3.73 Ratio and getting a brand new diff from a SRX that would be as strong as a 3rd gen diff in the V and you would have to do the same mods I mentioned above. This seller took my offer for $480 for a brand new one. Check it out. http://www.ebay.com/itm/251221874036...84.m1439.l2649. PART # 19178781
    Make sure you get the G80 option for limited slip and Gt4 option for 3.73. Good luck.
  4. #4
    ls6junkie is offline Cadillac Owners Member
    Mar 2012
    SE WI
    8
    Re: Rear Diff???
    QwkRhino, That is some great information. Do you have a picture or better way to explain the inch of material we have to cut off? Also what is the process for changing the pinon flange, I assume it is all accessible outside of the diff, I.E. we don't have to split the case, correct?
  5. #5
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
  6. #6
    Mar 2012
    SE WI
    8
    Re: Rear Diff???
    Interesting posts Darkman. Perhaps it's that I'm such a visual learner but I still am un-clear on what exactly needs to be cut off to get these SRX rear ends to work in the V's.
  7. #7
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Re: Rear Diff???
    Quote Originally Posted by ls6junkie View Post
    I have not looked at one, but I gather that it becomes obvious once you have one in hand together with the drive shaft you are trying to attach to it.
  8. Remove Advertisements
