can you rec an iPhone code reader and OBD-II connector
Results 1 to 9 of 9
2004-2007 Cadillac CTS-V General Discussion Discussion, can you rec an iPhone code reader and OBD-II connector in Cadillac CTS-V Series Forum - 2004 - 2007; Gentlemen, I'm in need of a code reader that will work on both my V and my wife's 06 MINI. ...
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Gentlemen, I'm in need of a code reader that will work on both my V and my wife's 06 MINI. I would like to use my iPhone. What's a good app that can be bought on the app store?
    Also, what's the best way to connect to the OBD-II? I see both cables and bluetooth readers, but I understand not all bluetooth readers are compatible with iPhones.
    Would love to hear what you're running and if you can recommend both an app and/or a wired or bluetooth connector?
    Thanks!
    HAM
  2. #2
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    Re: can you rec an iPhone code reader and OBD-II connector
    Which values are you trying to record?
    I use Harry's Lap Timer on my Iphone4 for recording video of autox and HPDE. It can interface with Wifi OBDII dongles and display RPM/Gear/Throttle and record values. My friend has one of these that I played with a bit.
    http://www.amazon.com/Yongtek-Blueto...s=elm+327+wifi
    You may want a different app for diagnostics and such.
  3. #3
    ken255 is offline Cadillac Owners Member
    Automobile(s): CTS
    May 2013
    39
    1
    None of bluetooth adapters work with iOS devices unless it is jailbroken. iOS devices need Wifi obd adapters.
    Kiwi 2 wifi is the best wifi adapter, I think. But you can find much cheaper ones on eBay.
  4. #4
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Glad I have an Android then...
  5. #5
    mackey is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Black
    Sep 2012
    172
    Dash command is the only one I'm aware of that allows you to read and clear codes on an iDevice and doesn't need a jailbreak IF you use the kiwi2/plx. If you use the cheap BT readers on ebay you'll need a jailbreak
  6. #6
    Apr 2012
    Seattle, WA
    731
    Thanks, guys. Hearing all this is almost enough to make me switch to Android.
  7. #7
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    Quote Originally Posted by HAMSTAR View Post
    Do it!
  8. #8
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    DashBoss is better than DashCommand (or so I hear) ... http://www.cadillacforums.com/forums...ml#post3384857
  9. #9
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    I have Rev. Works, but it's annoying as hell trying to get it to read OBD2 data off the Kiwi. Not sure if its a shortcoming of the software or the hardware. Btw, don't buy a Kiwi--get one of the identical generic nuts on eBay and save a bundle.
  10. Remove Advertisements
