Noob Linkage Advice
Results 1 to 10 of 10
2004-2007 Cadillac CTS-V General Discussion Discussion, Noob Linkage Advice in Cadillac CTS-V Series Forum - 2004 - 2007; Enjoying most of my new 2004 (80K), dark green metallic, catback, nice drilled/slotted rotors, K&N, a few other things: B.jpg ...
    JGeezer's Avatar
    JGeezer is offline Cadillac Owners Member
    Automobile(s): 2004 V (B&M, muffler delete), 2003 Corvette
    Aug 2011
    Connecticut
    71
    75
    Noob Linkage Advice
    It came with a short shift kit of unknown origin, and I've been very unhappy with the vague feel, hard to be confident of the 3rd-5th or the 4th-6th gate, so I got under there. Found some funky stuff:
    I'm not sure what the heck those bushings are supposed to look like, but it sure can't be like that.
    Any easy way to identify what kit this is, and what I need to sort it out?
    Thanks!
    JGeezer
  2. #2
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Re: Noob Linkage Advice
    That's easy. Those are the stock shifter bushings, and yeah, they're not supposed to do that. You can buy replacement bushings from Creative Steel or I believe Luke @ Lindsay Cadillac (UUC). Either way, they don't last forever. My UUC bushings went bad after 3 years. Here's to hoping that Revshift makes a set in 95A poly.
  3. #3
    PISNUOFF Guest
    Quote Originally Posted by FuzzyLogic View Post
    Oh man. I haven't even blown through my set of UUC polyurethane shifter bushings.
    The rounded bottom of the shifter stalk looks like a B&M.
  4. #4
    Mar 2011
    2,045
    Quote Originally Posted by PISNUOFF View Post
    Yeah, mine look much, much worse than his. I'll try to remember to take pictures this weekend when I do the McLeod RXT installation and other linkage mods.
  5. #5
    PISNUOFF Guest
    I made some outer linkage bar inserts that fit tight around the the pins and squeeze the rubber grommets if you don't want to use the Home Depot plastic bushing method. PM if interested.
  6. #6
    JGeezer's Avatar
    Aug 2011
    Connecticut
    71
    75
    Thanks to both of you guys, good info.
    I have been searching for the "Home Depot" fix, and just can't find it. Can you post a link? Thanks!
    JGeezer
  7. #7
    Mar 2011
    2,045
    Quote Originally Posted by JGeezer View Post
    JGeezer
    I would read this entire thread, if you have time.
    http://ls1tech.com/forums/cadillac-c...m-shifter.html
    But more specifically:
    http://ls1tech.com/forums/16892530-post94.html
    http://ls1tech.com/forums/16901269-post99.html
    Otherwise, you can read this one, but keep in mind that the Azn2dmax linkage that I purchased doesn't work with our cars. So don't go looking for that.
    http://www.cadillacforums.com/forums...eady-rock.html
    A whole bunch of guys (including me) have had no problem finding the Home Depot bushings, but I'm going to see what PISNUOFF made first.
  8. #8
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Still don't know why the old owner went for green metallic...
  9. #9
    JGeezer's Avatar
    Aug 2011
    Connecticut
    71
    75
    A problem? I have had nothing but solid black cars for many years, but this deep, dark, green is awesome.
  10. #10
    Automobile(s): ZIP
    51,885
    wut.
  11. Remove Advertisements
