Starter Heat Wrap ?
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V General Discussion Discussion, Starter Heat Wrap ? in Cadillac CTS-V Series Forum - 2004 - 2007; My starter was replaced recently. What is the best method to protect it ? Wrap it with heat wrap, or ...
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    Starter Heat Wrap ?
    My starter was replaced recently. What is the best method to protect it ? Wrap it with heat wrap, or I know they have the heat "bag" that goes over it ? Where do you recommend buying from ? I've seen them at AutoZone and so does Summit Racing. Does either option require removing the starter ? Thanks.
    Answering some of my questions =) I found a few on Summit; should I get the one with metal straps, or the Velcro ?
  2. #2
    jsnm is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Apr 2012
    14
    Re: Starter Heat Wrap ?
    I did the velcro one from summit,cut it to the size of the starter,put it on and also ran a few lines of safety wire around it to help hold it on as well.
  3. #3
    TheLostDriver is offline Cadillac Owners Fanatic
    Automobile(s): 04 CTS-V
    Dec 2011
    110
    Heat wrap is a must for longevity
  4. #4
    Wingsfan4life's Avatar
    Wingsfan4life is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V Black Raven
    Aug 2011
    Brooklyn Center, Mn
    46
    232
    Ditto...heat wrap it, got mine at pep boys for like $6.00...that ignition lead will melt again if you don't...
  5. #5
    Aug 2005
    Northern IN
    1,006
    All done. I bought the DEI wrap but was not able to use the velcro since I wrapped the motor and the solenoid separately. I was going to wrap the whole starter in one wrap but I was nervous about the metallic wrap and the end of the main power cable that attaches to the end of the solenoid.
  6. Remove Advertisements
