My brother and I are installing an Eldebrock E force 2300 tvs supercharger on a 2005 CTS-V. The problem is that the flange on the supercharger is for a LS3 throttle body which is a 4 bolt design. The 05 V has the 3 bolt throttle body. We are wondering if there is a adaptor or spacer to make this setup work. Thanks.
I would buy an ls2 or ls3 throttle body. The 78mm ls6 will be robbing power on a setup like that, and plus I don't think anyone makes an adaptor. I could be wrong though.
The LS3 throttle body is incompatible with LS6 and LS2 cars. The blade turns the wrong way, and no tuner thus far has been able to modify the ECU to adapt. If you ordered one, cancel the order immediately.
That is not correct Fuzzy, the ls3 works just fine with your computer if you set it up correctly, I have done it MANY times for MANY 2004-2007 model ctsv.. Just do a search, I was even putting in stock and modified ls3s in them for a while for people. Probably 18 or so? Some are on this board..
The only tuner that matters here is the tuner the OP will use. I never buy a throttle body/ intake combination without talking with the eventual tuner first.
Fuzzy, If you do a search on this forum, I posted what was needed to be done several years back. It requires me writing custom code in the computer operating system and some new tables put into the cal segment to allow for different things, then it works as advertised.... You can find a few members from this board running my ls3 conversion as well.
My brother has a tuner in Columbus that is suppose to get everything worked out. I'll keep you posted.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
